Question about Keurig Elite B40 Coffee Maker
Started leaking all water all of a sudden. Instead of making a cup of coffee, it all leak out from the bottom. water is luke warm. The Kurig barely 6 mos old.
  • Keurig Master
  • 1,711 Answers
The machine need to be desasemble and be working without side panel in order to visual find the leaking point, their many posible places and this the only way to find it.
This procedure need special care since their are many power cables are exposed when the machine is without covers.
Good luck and thanks for voding
Posted on Aug 10, 2010
Keurig b60 is pumping the water back into the tank instead of the cup as well it is leaking out the bottom of the machine, i have tried cleaning the needles however, not sure what's causing it to do t
Check the water output in the brew head itself. Open the head like you were going to out in a k-cup, and run a small object like a paper clip UP the water output to make sure it's clean. Then remove the K-cup holder and clean the water output line at the bottom the same way.
Mar 25, 2014 | Keurig Special Edition B60 Coffee Maker
Bunn coffepot will not heat or turn on.
after nearly 8 years of service a water leak shorted the heating element and the short caused a small metal thermal fuse to open
Sep 20, 2017 | Coffee Makers & Espresso Machines
My Cuisinart EM-100 Espresso Machine leaks water from the bottom.
Thanks Joe received ur gasket in mail installed it in 10 minutes and no more leak! The old was caked up above and below.
Dec 03, 2012 | Cuisinart EM-200 Espresso Machine
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
Our cuisinart kcup coffee maker is leaking out the top of the machine. When it brews instead of a stream coming out of the pour spout, the machine leaks water all over the main brewing piece (where the k...
Take out the used kcup and GENTLY explore the holder fitting. There should be a sharp point in the bottom that punctures the bottom of the kcup to allow the brew to flow out the spigot and into your cup. There also needs to be a sharp point on the top to punch a vent hole for the water to enter. It they aren't both open, coffee and grounds will spray everywhere. Take it apart and clean thoroughly as well.
Nov 02, 2017 | Cuisinart Keurig B50 Single Cup Coffee...
Our brand new Cuisinart model DCC-1150 10 cup coffee maker with the stainless steel thermal carafe makes a great tasting cup of coffee but the coffee isn't piping hot when first made and the carafe doesn't...
I am having the same problem, along with the coffee leaking onto the counter. I think this coffee pot is just defective. If not, I wish someone would come up with an answer.
Oct 21, 2010 | Cuisinart (DCC1150) 10Cup Coffee Maker
Mr. Coffee CG13 12-cup coffee maker. Have used it
There is high temp tubing that may have come loose or become dammaged fromheat or the coil that heats the water may be leaking if you are using strong cleaning chemicals to remove scale from the unit. The bottom is held on with screws. Remove these and look to see what is the source of the leak.
Nov 21, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
Cuisinart Grind and Brew 10 cup coffee maker warm water leaks from bottom during brewing.
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Oct 12, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Keurig Elite B40 Coffee Maker Logo
292 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
