Question about DISH Network 322 DTV Receiver
Tv screen says no signal - DISH Network 322 DTV Receiver
    Novelist:
  • 185 Answers
Hello! Daniel Busa here with Dish Network customer support, try this link : http://www.dishnetwork.com/SupportSection/video
Posted on Dec 30, 2010
I have astron tv 14 inches. when i connect outdoor antenna the. tv screen turn black. no signal. no reception but when i disconnect the outdoor antenna it turn to blue screen.
blue screen means 'no signal' or 'signal level is too low' whereas black screen means that there's a signal. Check your antennae, do a factory reset to your unit and then try initial setup.
Feb 26, 2015 | Televison & Video
The image on the screen looks like everything is in slow motion, the the color is messed up. I have already tried adjusting contrast, brightness, etc. Is this a fixable problem, or should I just buy a...
I know the colors are all messed up.But the tv LCD screen panel light it is bright enough to see the screen picture,and the tv LCD screen panel are clear,no purples,reds marks or bruses to the tv LCD screen panel itself?Yes,to all of these.The tv can be fixed.The tv Tuner signal board,that the board where the incomming broadcasting signal wire plug into it.The tv Tuner signal board it is dying and the problems to causes this.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.Will fixed this tv and get tv this to be working normal again.
Aug 20, 2011 | Samsung LN-T3253H 32 in. LCD Television
I have a 32lc7d tv and i cant get it to turn on all the time. the on light will be green but no sound or picture. the light also blinks about 15 times before going to a solid green color. the tv will...
This problems ur tv are having are only can be causes by two boards,the tv power supply board or the tv Tuner signal board.The tv power supply board that the board where the power a/c cord plug into it.The tv Tuner signal board that the board where the incomming broadcasting signal wire plug into it.This problems very easy to fix.If it is the tv power supply board is the causes,because u can check the tv power supply board carefully u will find dying capacitors parts that will bulging up or puffing up on to it tops.U have all the tools and know basic electronic just replaced all the dying capactors for all new capcitors parts same micro ferit but the capacitors voltages like 5 or 10 voltages higher for better heat resistance for the life of the tv power supply board.If it is the tv Tuner signal board,very hard fix and determine where the dying parts are in this board,because this board is cover with many ICS chips on this board.If the tv the Tuner signal board is the problems best just buy the whole refurbish tv Tuner signal board for the replacement.Or u can tries websites like Shopjimmy.com,Ebay.com to buy the whole refurbish tv power supply board too,if u don't know how to or have all the tools to replaced those dying capacitors parts and also can buy the whole refurbish tv Tuner signal in these two websites too.
Apr 16, 2011 | LG 32LC7D Television
My kdl55nx810 screen is blinking. While watching TV, the screen will go black for about 2 seconds, then come back on. It appears to happen intermittenly, every 15, 30, or 60 seconds. TV was working fine,...
This problems,it can't be repair.The tv Tuner signal board is problems and the the causes.The tv Tuner signal board have intermittent problems.That the board,where the tv incomming signal cable plug into it.Tv is still useable wright?Use it the tv as is.Or only way to repair it is to do a replacement of the whole tv Tuner signal board to fix this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Mar 15, 2011 | Sony Kdl-55hx701 54.6 in. HDTV LCD TV
Screen has gone to blue screen.....
OK A Blue screen, indicate that there is, or the TV "Thinks" there is NO SIGNAL. Please Check your Antenna Connection. Unplug the TV, for 5 mins or so. You MUST prove either the TV or it's "Signal Source" the Antenna. Try the antenna on another TV, if possible, try another antenna,on the TV, Try feeding in a signal via the EXTERNAL inputs. IF ALL Inputs are proved OK, and the TV, still will NOT display any signal, then it would appear that you may have a "Tuner" fault, or some other underlying condition, that affects the reception. In my professional opinion, in that case is to get the unit looked at by a Toshiba, recommended service center, VERY IMPORTANT to do that. Ask for a "Quote" from that service center, and go from there.
Apr 16, 2010 | Toshiba 37AV500U 37 in. LCD TV
The picture doesn`t fit the screen. Daewoo DWX-28W5GB telly
Sometimes the box that sends the signal to the TV preconditions the signal to 4x3 or 16x9, depending on the capability of the TV. I always opt to the "no fit" option and allow the intelligence of the TV to fit the screen.
If you have "off air" TV signal without that preconditioning, I cant help.
Oct 02, 2017 | Daewoo DTQ-20U9SC TV
TV screen reading no signal. We have satellite
tune in tv or put tv in AV / EXT mode the no signal means not tuned or on areal in tv
Nov 28, 2009 | Sony Televison & Video
Dark blue screen with words: Cable, Digital TV, No SIGNAL. Brand new TV.
that says it all... no signal look at your owner's manual to set it for TV
May 22, 2009 | Initial DTV-322 32 in. TV/DVD Combo
Durabrand TV/DVD dct1481
The blue screen is fairly common and is displayed when inadequate signal is present.
In other words, 'no reception.'
The weak BBC1 signal is kind of a confirmation of your poor signal strength.
Aug 20, 2008 | Durabrand DWT1905 TV
Tv problem
Your TV is telling you that the cable, antenna, or another input has no signal coming into it. When there is no signal, the set mutes itself to a blue screen to avoid your seeing "snow" on the screen. You need to check your connections. IF all are O.K., then your problem must be in the tuner or A-V input. Stargazer
Dec 17, 2006 | Durabrand DU1901 TV
DISH Network 322 DTV Receiver Logo
139 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
