Question about Marconi Systems Marconi ESR 5000 Series II Router
Looking for a marconi esr 5000 manual - Marconi Systems Marconi ESR 5000 Series II Router
I am looking for a user manual for the Marconi LKA 900 phone
Go to mfg web site or try google search.
Sep 17, 2017 | Lands Phones
Marconi lka 900 user manual
Try Googling (Marconi)(lka 900)(manual) without parens.
Jul 14, 2014 | Lands Phones
Finding Marconi radio schematic model79-c
If it is a 791 instead of a 79, check here:
http://bama.edebris.com/manuals/marconi/
you may find a similar model.
If it is a Marconiphone,
http://www.nostalgiaair.org/Resources/246/T0000246.htm
Although there were some Marconi models that may not be int he Nostalgia Air database for any number of reasons, partly due to the fact Rider usually put them in with the Miscellaneous models.
Other possible sources could be in the various "Shortwave guides" that were published in that era- many included schematics from the manufacturers. Lindsay publishing has reprinted 1936 and 1937, whether they are still available is tough to say, but you can check the listing of what Lindsay publications has on hand at http://www.lindsaybks.com just look for the book list.
My own suggestion- Recap it completely first. Then check the resistors to make sure none are outside of the tolerances- usually 20 percent. From there, tweak the IF;s and the radio should come to life even with weak tubes.
If you are in the UK, or Europe, there should be a few dedicated museums that may have the schematic available as well- just use search engines less used. In other words- forget google or bing- Although google.de or google.it might give you some hits if the radio is not of US manufacture.
Feb 16, 2012 | Radio Communications
My Marconi modem is fine until I install Norton 360 and then it has some kind of conflict and windows cannot detect it anymore and I can't access the internet!!
Forget Norton 360, it has been causing major Problems with a lot of programs,
go to www.majorgeeks.com and get AVG Free edition
AVG is free for life, scans more of your computer than Norton, and uses less than 1/3 the resources of Norton on your system....
Sep 14, 2009 | Marconi Systems (NMFR-4/E1A) Modem
Sinalling channel is not comming up in marconi TNX-210
kindly reinstall your physical layer & reinstall drivers
Jul 01, 2009 | Marconi Systems TNX 210
Manual for Vitamix 5000
Manual-Cookbook -Getting Started $0.99 1 bid. Buying Info 4d 21h 52m ...
shopping.superpages.com/vitamix+5000~BEFID_96301 - 60k - Cached
Jan 22, 2009 | Vitamix 5000 Work Top Blender
Marconi 2951 radio test set vintage
possibly a power supply problem - check current drawn from the power line compared with your other 2951. any disturbance in power supply voltages can kill the afc/pll in older service monitors. if you have the manual check the ps voltages
Sep 21, 2008 | Radio Communications
Login into console
user/user system/system super/super http://tactics.marconi.com/kms/detail_controller.cgi?contentId=2587&productId=47 http://tactics.marconi.com/kms/detail_controller.cgi?contentId=3558&productId=47
Aug 23, 2007 | Marconi Systems Marconi Service Edge...
Marconi Systems Marconi ESR 5000 Series II Router Logo
94 people viewed this question
Top Marconi Systems Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Marconi Systems Computer and Internet Expert? Answer questions, earn points and help others
