Question about Sylvania LC320SLX 32 in. LCD TV
My LC320SLX Sylvania TV displays the message "Format not supported" when I plug in my new Mac Mini computer. I am using HDMI cables to connect.
  • 11,361 Answers
You are getting that message becuase the MAC video resolution is too high for the TV handle, you need to lower your MAC video resolution to the native resolution of the TV, read your manual to find out what it is.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 08, 2010
Connect 26pf5520d to a mac mini
Try to connect your Mac Mini to another DVI-capable monitor. May be your DVI out on Mini doesn't function at all
Aug 29, 2017 | Computers & Internet
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
I would like to use my Sylvania LC320ss8 Flat screen tv as a computer monitor but when I plug in the monitor plug the screen on the tv says format not supported. My operating system is Windows 7 and...
If you have connected the TV to the computer with a VGA cable, what resolution was your previous monitor using? You may need to change the resolution or refresh rate with your regular monitor attached. This TV has a native resolution of 1366 x 768 .
If you are connected via one of the HDMI ports, check the specifications for your TV. Then try using the VGA output. Not all TVs support a computer signal over HDMI. Unfortunately, I can't find the LC320ss8 at the Sylvania Support site: http://www.sylvaniaconsumerelectronics.com/ . If the model number has an error, click on Downloads and enter the correct model number.
I hope this helps.
Mar 31, 2011 | Sylvania LC320SS8 32 in. LCD Television
How do you connect a mac to an HDMI device and can you get sound to the tv ?
Hey, you would need a Mini display to HDMI cable and unfortunately the sound cannot be ported through the mini display port.
Mar 14, 2011 | Apple Customized 15" MacBook Pro Laptop...
When I connect my unibody macbook pro to my old tv using a vga to tv converter, my computer doesn't even recognize the disyplay.
When you connect your tv to your mac, make sure the cables are plugged into the TV first, and then plug your mac into the computer.
But a vga to tv converted doesn't make much sense. Your connection should be mini-display from your mac, to an adapter to either VGA, DVI, or HDMI depending on your TV connection type.
Dec 31, 2010 | Apple Computers & Internet
FORMAT NOT SUPPORTED FOR PS3
If it's one of the original PS3's (might be the same for the new) you can hold the power button down when you're powering it up until it beeps and then let go of the power button. This will make the PS3 search for what video devices are plugged in. If you're using the HDMI it will say "An available HDMI device was detected. Do you want to output video and audio using HDMI?", and you wan to say YES. Then it will automatically set the resolution (should set to 1080i) and give you 30 seconds to confirm the video works by saying YES again. This TV will not support a 1080p output so if you try to change the PS3 to 1080p resolution it will not work.
Dec 20, 2010 | Sylvania LC320SLX 32 in. LCD TV
Sylvania tv says format not supported when ps3 is plugged into it, just happened use to work fine
I have also received this message when I had a bad HDMI cable.
Nov 29, 2010 | Sylvania LC320SLX 32 in. LCD TV
PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
Dec 22, 2008 | Sylvania LC320SL8 Television
Sylvania LC320SLX 32 in. LCD TV Logo
584 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
