Question about Toshiba 57H81 57" Rear Projection Television
Hi, is this an IC chip problem?
Hi
i think i have a toshiba 43vj13p, the colours arnt lining up, so i checked this site (great site btw) and i found a really helpfull post about replacing ic chips.
Do u think i might have the same problem
This is a sample of what my screen looks like
http://img30.picoodle.com/img/img30/4/4/27/f_Samplem_208e3ff.jpg
  • Anonymous May 18, 2008
    the blue will not line up,,even if i get it back to where it is lined up with the rest on the convergence screen ,,it shifts to the right before my eyes?
  • Toshiba Master
  • 8,617 Answers
Yes that chassis should use STK392-110 you need to replace both heres a link where you can get new replacement ICs and they provide free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Apr 27, 2008
Coloured vertical lines on LED Tv
It sounds to be a T'Con board fault. Check it. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 18, 2014 | Televison & Video
I have bought a one for all remote and the codes wont work for my toshiba 43vj13p tv
Just check it with some other codes to different brand remote control. This is a common problem with Toshiba brands. If you wish to get more codes to different other brand remote controls, check this link. Setup codes and proceedings to many brands of popular remote controls are given in detail. Check this link too. Pull up older posts there.
Feb 23, 2013 | Televison & Video
Toshiba 65hdx82 convergence issues
check fuse resistors near STK, and broken PCB around digital convergence board (board in a metal box verticaly mount beside STK.
Apr 23, 2010 | Toshiba 65HDX82 65" Rear Projection...
Location of convergence chips in Toshiba 57H81.
hello if you can use a soldering iron you shouldn't have any problems but you will need to test the resistor in front of the ic and the capacitors at either end of the ic ! the ic usually located to the right hand side of the tv behind the tuner board connected to metal frame called a heatsink 2 big black chip good luck
regards
shaun
Mar 27, 2010 | Toshiba 57H81 57" Rear Projection...
Hi there ive got a toshiba 43vj13p very blue picture
Hello, you can then buy a replacement lamp or lamps Toshiba 43VJ13P? Thank you
Dec 21, 2009 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 43vj13p
if the people in the pic has red out lines or looks like theres two of them then sounds like convergence problems which you will need to replace the convergence chips which cost around £150 +vat. hope this helps
Feb 10, 2008 | Philips 50P8341 50" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Toshiba theaterview lines don't line up
Convergence IC blown stk392-???
Dec 03, 2007 | Televison & Video
Hi toshiba 43 rp
You have a confusing mixture of data......Please provide
Make,model,age and chassis off sticker on back of set.....T.
Nov 26, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba power led blinking
check your horonital output transistor could be defective.
Jan 26, 2007 | Toshiba CZ36V51 36" TV
Toshiba 57H81 57" Rear Projection Television Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
