Question about Homelite Garden
The trimmer head does not spin, when the shaft is disconnected from the power source it spins freely. The drive componant bolted to the motor is frozen, therefore the motor cannot spin the shaft to drive the head. In need fo a service manual in order to take off the power source. Please advise Best regards Tony
  • 51 Answers
Remove shaft from power head check to see if drive shaft end is square if ok grab drive cable with pliers and try to turn head while holding pliers to make sure other end of cable and gear box are ok if so may have broke spring in clutch. remove plastic cover from engine you will see clutch bell remove spark plug stick piece of rope in hole to stop piston from moving where cable would go in bell there is a screw that holds bell on either torx or allen remove screw and take bell off there will be 2 shoes ans 2 springs that hold shoes togeather end of springs usually break where they hook in to shoe hope this helps
Posted on Aug 08, 2010
Testimonial: "The advise was sound and was from an individual that has experience with theses matters and more impressive he was able to give simple instructions."
  • rnrx Aug 12, 2010
    Thanks for the advise, I did what you said and found that the clutch housing had melted to the clutch. I cleaned up the molten plastic reassembled it and it worked great!! I checked the spings while apart and they were fine aside from some wear.
    Thanks again
    Best Regards
  • Leonard Fleming Aug 12, 2010
    glad to be of help thanks for kudos
Husqvarna 128ld trimmer head turns slowly,why
Make sure debris is not wrapped around the cutting head. Remove the cutting head and clear any debris. Then see if the drive shaft spins freely. The problem could be either where the drive shaft mates with the clutch on the powerhead or the clutch is worn.
Jun 08, 2014 | Husqvarna 128LD 17" Gas Trimmer
TB70ss clutch
Check to see if there is any material collected around the base of the head, around the tube that provides the energy to spin. It may cause the power to be diminished a great deal, so that must be cleaned away thoroughly. Check to see if you can spin the head freely by your hand, without the motor being on. If not, it may need lubrication down the indide of the power shaft. A light grease would do that, or even a heavy oil poured down the shaft, but not too much.
Sep 20, 2012 | Troy Bilt Tb70ss Gas Trimmer
Head not spinning shaft cable is.
place a screw driver in the slot the drive goes into and hold the trimmer head feel the head
Aug 16, 2012 | Troy-Bilt Troybilt Mtd String Trimmer...
No power when wheel spins
You may have a broken drive shaft. Some are braided and flexable and used on curved shaft units. The solid shaft is used on most straight shaft units. Remove the string head and pull the shaft out to look at the ends to see if they are broken or stripped. George
Jun 05, 2012 | Homelite Consumer Products 4.0 Amp, 13 In....
The motor is working but the trimmer part stopped spinning. I checked the line but there is plenty, I removed and replaced the line spool but still not working.
Does the trimmer head spin freely? If so then it is somehow disconnected from the motor. There should be a motor coupler somewhere near the motor and also near the trimming head. Make sure they are connected.
Jun 06, 2011 | Black & Decker 14" Grass Hog Xp...
Motor works fine, but trimmer will not rotate
Have an assistant start and hold the trimmer. At idle, there should still be a little drag on the clutches to make the shaft spin on that split shaft trimmer with the accessory head removed. No need to rev it or do anything fancy, but teamwork will make it safer.
Now forget about the engine and clutches - does the accessory head spin freely when turned by hand (removed from engine still!) and with a clear rotation of the shaft end visible inside the connector socket? Is the shaft end square with sharply defines angles, or rounded off? Does swapping in a different accessory function normally and as expected?
Sometimes the nub end of the shaft wears. Worse, the socket on the engine side has eaten itself to pieces. Worse, worse yet, clutches in the engine side that engage the accessory shaft are worn and there is simply no transmission of power. Good luck, hopefully this info will set your boots in the right direction!
May 08, 2010 | Craftsman Convertible 25cc. Gas Line...
Feather lite weedeater disconnected shaft and
You may not have the drive shaft seated all the way into the power head.
You will have to loosen up the drive shaft and push the shaft in but at the same time turning the trim head to fit it into the drive area, then tighten it back down.
Oct 03, 2009 | Poulan Garden
The trimmer head will not spin under power
The drive shaft is not set all the way into position. You will have to take the front casing off, as well as the lower part of the shaft, and work it into position that way. You may have to play with it a little bit.
Jim
May 30, 2009 | Homelite Mighty Lite Lawn Trimmer
Trimmer dust cover hot to touch ... trimmer head flew off and in reinstalling the trimmer does not turn or only turns momentarily before engine shuts off
sounds like the drive cable is jammed.you need to remove the shaft from the engine and head and see if the cable spins freely.
Apr 29, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Garden Logo
190 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
