Question about Pioneer DVR-220 DVD Recorder
I can not get my recorder to work when I plug it in it dose not come on. I lost power a couple of times when I was at work now it will not come on. where can I get it fixed
  • 3 Answers
Check the in line fuse...If you remove the unit cover the inline fuse sits right behind the plug socket...If the fuse is okay, then you will need to replace these two capacitors on the same power circuit board...One is at location C19, 3300uf, 10 volt, and c23, 1000uf, 10volt...
Posted on Aug 12, 2010
Why dose recording in dvr goes on default date when light goes
Well, I'm trying to decipher this. Why does the recording in DVR revert to the default (date/time???) when the light goes off and comes back on.
I'm guessing you are trying to say time, not date, maybe day?
The DVR is trying to remember when a show comes on and record it, based on your settings. Usually shows come on at a specific time. DVRs usually update their scheduled recordings based on updated programming guide information. If you are constantly unplugging or causing your receiver to otherwise restart, most receivers will download an updated guide upon getting power back or restarting (DVRs themselves not having any idea how long they've been without power, download a new guide just in case after you unplugged them you moved to Arizona). During this time, the recording you set is showing the original time you set it up, because until the guide is downloaded, it has no idea that its wrong.
My best advice, even if I'm wrong about our language barrier here, stop unplugging your receiver. Leave it plugged in and powered at all times.
All times.
For ever.
Dec 18, 2016 | Televison & Video
Can you initialize a DVD-RW after you have recorded on it?
hi its geoff
yes you can. i dose say that no more recording can be done after the disc is finalized (thats true, you first have to unfinalize the cd to write more files on it.but you can initialize the disk at any time but you lose the recorded content(it frormats the disk) then you can use the disk over and over again. remember finalizing and unfinalizing requires you to plug the mains charger into the camcorder it assumes theres not enough power in the battery to do the job and will need the mains every time.but initializing only requires sufficient battery power .
Aug 10, 2010 | Canon DC210 DVD Camcorder
Once power is on hello is contineously scrolling DVD eject is not working
A couple of universal things you can try. Power unit off, unplug for 5 minutes, plug back in, power on.
Another thing to try is same as above, but when powering unit on, also press the stop button at same time.
That has worked for me in the past. Hope this helps.
May 27, 2010 | LG RH177 DVD Recorder/HDD Recorder
My Sony 52" LCD kdlw3000 tv, which is almost 2 years old, went to standby mode after our power had been off for two days due to a storm. TV worked fine before we lost power and it's plugged into a surge...
Just as our modern sets can remember user settings when the AC goes off, they well may record error conditions for an extended length of time too just as our cars do. Flash memory (used in such applications and only type used in digital cameras for example) can keep information for a very long time. Even if not used in your set, there is surely backup provisions that can keep info handy for days and possibly weeks by using components that mimic batteries to retain even standard memory for weeks.
Most PCs have provisions for discharging this kind of circuit which then resets possible stored error conditions and returns stored values to factory conditions.
Feel lucky this time I'd say.
Nov 02, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My honda has lost its power. feals like something
Has it been hot. That can do that. If not. Look at the plugs / how long they been in. / If it has a timing belt,and I think it dose it may have sliped a little. Check the belt all the way around see if there is a bad place on ti on the inside. may have a tooth or two gone. If so that it it. I had one do that to me.
Ken
Sep 26, 2009 | 1987 Honda Civic
Tray wont open on my philips cdr600 recorder , can it be fix
You can try the following:
Unplug power cord.
Plug back power cord.
Press start and push repeatedly the eject button while the unit is starting, before the Player start reading the CD.
Try this a couple of times.
if that does not work, then you will need to disassemble the unit, unplugging from power, and removing the screws at the bottom and at the back, to access the drive and remove disk manually.
Jun 18, 2009 | Philips CDR600 CD Recorder
Power does not come on
i have had this problem time and tim again with the cyberhome dvr 1600 dvd recorder its not the fuse thats the problem the converter on the power board is blown i have 7 of these with exactly thesame problem to fix it all you need is a new power board if you unscrew it and take the top off then the power bord is to your right hand side big long board where the mains plug in all you do is once you got a new power board unscrew the old one and screw the new one in and plug the cables back in boo it works and by the way i had 7 of these plugged in when lighteing struck and its the same problem with them all
May 19, 2009 | Cyberhome DVD Recorder - DVR1600
Boss br-8 digital recorder wont load up. powers up but no program
This Sounds Very Bad Do You Have Experience With Taking Apart Computers? If So You May Want To Open Up Your Br-1180 And Remove The Hard Drive And Put It In Your Computer And Copy All The Data Off Of It. I Also Would Recommend Calling Roland They Are The Most Helpful People In The World.
www.Myspace.com/CrossRoadsToNowhere2007
Dec 28, 2008 | Boss Micro BR Digital Recorder
DVD+RW playback problem(s)
same prob with the shows freezing up
with a DVD+/- RW disc the amout of time keeps dropping because with every recording process the disc loses a life you can burn those disc 200 times before they become useless so the disc might be beyond the life peroid or bad
my prob is with the DVD-/+R disc tho and i figured it out the disc was bad
for the grinding noise if its hi piched its normal thats the disc spinning up to read or write speed
if that not the case something is rubbing in there and that might explaine the writting errors
**DISCLAMER**
the disc manurfacture dose not take resposnablity for defective disc and any loss they have caused(if the data is lost)
Aug 23, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Open Questions:
Pioneer DVR-220 DVD Recorder Logo
238 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
