Question about Krups FBC4 1600 Watts Toaster Oven with Convection Cooking
How do you change the top heating element on the krups fbc 412?
    New Friend:
    Problem Solver:
  • 17 Answers
Based on the markings on the sockets, there are 400W ones in the center and 600W ones on the front and back. That adds up to 1600W on each, the advertised total. So be sure you have the correct replacement. After removing the cover you will see that each one has spring connectors.
Posted on Aug 10, 2013
3 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 02, 2009
  • 3 Answers
SOURCE: My Krups FBC 1 toaster
Most of the time a hardware store will have a variety of springs or try home depot.
That's if you only don't want to wait for a manufactors spring.
Posted on Dec 20, 2010
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Where can i get a diagram of a Krups FBC412?
Maybe Krups can provide the diagram if you inquire.
Aug 20, 2016 | Krups FBC412 1600 Watts Toaster Oven with...
My Krups FBC 1 toaster oven has a broken spring for the glass door.
Dec 19, 2010 | Krups FBC1 1600 Watts Toaster Oven with...
ELECTRONICS SEEM TO WORK (ON/OFF; TIMER; CLOCK; OPERATION SELECTIONS [TOAST, BAKE, ETC]) BUT ELEMENTS DO NOT LIGHT UP
check the resistance of the plug by turning the timer and temperature switch, if there's no resistance, open your unit and check the resistance of thermal fuse which is connected to line wire. it is look like resistor..if the thermal fuse is ok then check the resistance of heating element..
Sep 30, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
Toaster not heating high enough
either the high voltage regulator is failing (you can test with voltmeter) Or the heating element is bad. You can test power to element.
Oct 24, 2009 | Krups FBC112 1600 Watts Toaster Oven with...
The heat element doesn't go on
FInd the break in the heater eliment and twish it bac together. It will then work again for a while.
Jun 29, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 30, 2009 | Krups Toaster Ovens
Mar 02, 2009 | Krups FBC2 1600 Watts Toaster Oven with...
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Krups FBC4 1600 Watts Toaster Oven with Convection Cooking Logo
347 people viewed this question
Top Krups Toaster Ovens Experts
Stan Ford
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
