The tub is full of water and won't spin out, when on spin it is not moving all i hear is a hum
  • Washing Mach... Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinethe tub is full of - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 08, 2010
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Doesn't spin
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 29, 2012 | Kenmore Washing Machines
I have a GE Adoration WHDRE526E1WW top load washer. It drains and hits spin but will not spin. Lid switch seems to work. When tested the motor kicks on but will not turn the tub. Few times I manually spun...
It really sounds like the belt. You say it's in good shape but if it's loose or shiny from not having proper tension it wont have enough friction between the belt and pulley to actually work. If you've ever tried to move the drum when its full of clothes and water you know how much force id needed to function. Double check that belt tension and working surface.
Aug 13, 2017 | General Electric Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
I have a fisher and Paykle GW612 washing machine, it won;t drain the water and won;t do the spin cycle. It now is making a huming noise. I think it is the motor that has an issue?
There should be a tech sheet located underneath the control panel that has the procedure for putting the machine in "diagnostic mode" and you can easily run the water pump by itself. Listen for a "hum" sound- If you hear a hum instead of a running water pump, then something is keeping that pump from turning for sure.
If this is the case, then you would need to check your water pump. It is located underneath the machine in the right front corner (as viewed from the front of the machine)
There is a black plastic external cooling fan impeller that you can spin with your finger (of course unplug the machine first) and see if the pump spins freely. You should also examine the pump for signs of leakage or corrosion. You may simply have an object that was left in someone's pocket that has become lodged in the pump. Pump removal requires no tools, however you need to first bail out as much of the remaining water in the wash tub as possible.
Jan 15, 2011 | Washing Machines
Will not spin
The humming sound is most likely the pump running. Try this: Open the front panel by using a putty knife to push in the clips (2) at the seam where the front panel meets the washers top. With the washer in the spin cycle (you hear just the humming) pull the little hose off the left side of the outer tub, near the bottom. The washer will most likely begin to spin immedeately. If it does, this would indicate that the hose and the nipple it connects to need to be cleaned out. Gunk builds up there some times and then the air cannot escape back out, so the washer thinks it is still full of water, and thus will not spin. After cleaning those out, replace the hose with the tub empty of water. If the washer did not spin after pulling the hose, check the lid switch.
Mar 29, 2010 | GE WBSR3140DW Top Load Washer
Mah 6500 spins but leaves som water in tub. if you
they have a balance ring on the front of the tub and it's full of water
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't agitate
Just fixed the same problem. Its a broken belt. Take the front panel off and to the right of the tub you will see a pulley and belt. We replaced both the pulley and the belt for around $40. Was real easy to do yourself.
Nov 27, 2006 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
