Question about Dryers
My dryer keeps causing my fuse box to blow! causing all electrical appliances in the appartment to switch off. I have tried to change the fuse in the plug but it still want work.
  • jillmburger May 11, 2010
    my roper dryer keeps triping the circuit, what do you think is wrong with it?
  • 78 Answers
The heating element is probably broken and touching against the back part of the drum casing, causing a direct short circuit, causing the breakers to trip. don't try it anymore untill you check the element first.
Posted on May 03, 2008
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
Clean Lint Filter Light Keeps Dryer from starting
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
Oct 06, 2008 | Frigidaire FGQ1442ES Gas Dryer
My whirlpool dryer keeps blowing the fuse for heating. The dryer will still tumble but once stopped, won't start until the fuse is replaced. We've cleaned the whole thing out and even set up a different...
I would check the outlet as it sounds like one of the wires is off/shorted. Here is a website that may assist you, Good Luck Tim:
http://www.applianceaid.com/general.html#timers
Nov 01, 2010 | Kenmore 63932 Electric Dryer
My Maytag Bravo Steam Dryer runs for about 5 minutes and gets hot and then kicks the breaker in the breaker box. HELP!!
Hello there:
It blows fuses or trips the circuit breaker Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:It could be also wired backwardes so make sure to have this checked'
If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician. If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box.
May 21, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer is overheating and blowing circuit
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Aug 04, 2009 | Whirlpool WED5300S Electric Dryer
I have a whirlpool dryer, model number GEC9858EQ0, that did not restart after opening door to check the laundry. I have ohms checked the start switch and door switch. where do I go next?
    Good luck
  • Regards:
  • VOTIT
Jul 01, 2009 | Dryers
Blowing breaker
hi. I can help you.
Jun 22, 2009 | Kenmore 63942 Dryer
LG Dyer blows 30amp fuse frequently
Hello davidkado,
There is a high probability that when you replaced your fuse box to circuit breakers that the wiring at the fuse box was retightened. If your dryer had been operating Ok for the better part of a year and then you started to blow fuses on a regular basis.. chances are the wiring coming from the fuse box tap was becoming loose from thermal expansion and contraction and that by changing to a breaker system.. your wiring was cut and reterminated to fit the breaker tap. I suspect you won't be having any additional problems...
Regards,
Rick
Jan 02, 2009 | LG DLE2514 Electric Dryer
Tumble dryer will occasionally cause the trip switch to blow. we can not the put the power back on till we have switched dryeroff at socket
Hi, Thanks for the question The problem you are having is with the fuse box . Its common to have the contacts in the fuse box to corrode . and cause the fuse to over heat . and blow .So replace the fuse box for the dryer . Thanks the appliance doc
Sep 30, 2008 | Dryers
4 dryers broke in a row
hi thanks for the question does the dryer keep blowing the fuses after a short time if this is happening the problem is in the fuse box for the dryer .the fuse box has a loose connection . so every time you use the dryer the fuse gets hot & fails . replace the dryer duse box thanks the appliance doc
Sep 28, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
