Question about RTO American Heat Tankless Electric Water Heater
Wired yellow to green,blue to black,red to red.bearker trip
  • natfl Aug 08, 2010
    tankless water heater has yellow,red, blue wiring,need wire it to red,black,white
    Dont see two other message posted.I wired disconnet box wrong.Just ordered a new breaker one side blue out.did not try the unit ,the disconnet box doesnt work good now eather,must get new parts first.To be sure I must get info to wire the only three wires in a cord whitch are yellow,red,blue to red,black,white.60 amp breaker,#6 romax wire
  • 2,841 Answers
What model is your Electric Tankless water heater? I will need to see the specs of the unit before offering advice.
Posted on Aug 09, 2010
  • natfl Aug 11, 2010
    american heat super-adk 1 ,Have three wires,yellow with green strip,nuetral?,Blue,red,load?please send email before new breaker sent to me.
  • NOT ME Aug 11, 2010
    The Super ADK-1 requires a 60 amp 240 volt breaker and you must use #6 AWG gage wire. This unit draws a max of 57 amps so nothing smaller is safe. This is very large wiring and hard to work with but that is what it takes. Make sure you get a 60 amp disconnect. If you can see the water heater from the service panel you do not need a disconnect. If not a disconnect is mandatory. The incoming electrical service will have 2 wires and ground. Black & White are each are hot and each carries 120 volts for a total of 240 volts, Green or solid copper is ground. On the heater the scematic should show you which is hot and which is ground. I would think the red and yellow are hot and the blue is ground but to be sure look at the unit.
    President:
  • 2,030 Answers
Can you give me the model # of your unit?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 08, 2010
  • 6 more comments
    american heat super-adk 1 tryed two wire ,red to red,yellow to white,blue to black,breaker trip
  • Sean Wright
    Sean Wright Aug 08, 2010
    You just told me a different way you hooked up the wires then in your first post...
    How are the wires connected?
    And....what size breaker is on the circuit controlling it?
  • Sean Wright
    You need a 60 AMP breaker for that model...if your breaker is less than that, then it will keep tripping even if the wires are hooked correctly.
    Here is a copy of the install manual...
    http://www.americanheatus.com/downloads/...
  • Sean Wright
    You do realize I hope that this is a 220V appliance and needs to be hooked to 2-3 b reakers( depending on model) and it is not a single breaker hookup.
    Found that both red
    found both hot leads on same post in disconnect box, changed them but will not wire the unit until I am sure how to.The diagram doesent,match what I see.Need to wire yellow,red,blue to red,black,white
    have 60 amp breaker
    have #6 romax wire
  • 12,061 Answers
OK Black is the PHASE... In USA, So that may actaually go to the RED, goes to the Black. The Green MUST be earth
So I guess that leaves RED as Neutral? Doesn't sound right, so I wonder if your wiring is right.
The breaker trips because there is a short circuit, OR the Phase is touching Earth.
It does sound logical though the way you have it wired, I would have thought that would have been correct...
Are you sure you don't actually have fault, within the unit?
You need to meter the Phase & Neutral, and see what's what. IF you DO have it OK, and I suspect you do, then there MUST be some other issue.
    my message was mistake,red to red,white to yellow,blue to black,in the disconect box.Couldyou send another massage.Thank you
    need to know how to wire yellow,red, blue wires to red, black, white, 220 tankless water heater
Gc10a-4ewater heater attachmentioned of colored wires to the back of water heater
black white and green power 120 volts other wires red yellow and blue and green 12 volt to control board
Oct 13, 2017 | Water Heaters
How can I make a thermostat connection?
Good morning Yakup.
The best way is to write down how the old t-stat was wired. If that's not available, the only way to determine for certain where each wire goes, is to check what the installer did at the terminals in your home comfort system. Please note the there is high voltage electric in each piece of equipment so if you decide to open up panels, there is always the risk of damaging the equipment or worse, injury or death if you are not a qualified service technician. However, typical color assignments are as follows:
R= (24v from heating appliance) Red
RC= (24v from cooling appliance) Red
These two are only separated when you have two different appliances providing seasonal comfort, like a boiler and an air handler. If you have a warm air furnace with an air conditioner or a heat pump attached then R+RC will have a jumper across them and only one RED wire will be landed there
W= (heat) White
Y= (cool) Yellow
G= (fan) Green
Those colors are pretty standard
The rest of the colors depend on availability in the jacket and are really up to the installer. You mentioned 7 wires but 8 conductors is more likely so I'm assuming the remaining colors are black, brown, blue, and orange.
I always use the following:
C= (common) Black
O/B= (reversing valve for a heat pump) Orange if the valve is energized for heat and Blue if the valve is energized for a/c.
Aux/E= (auxiliary or electric heat) Brown
L= I believe this is a diagnostic terminal for some systems with feedback data and is not used frequently.
After wiring there is some programing to do to set up your new thermostat to your type of system.
Hope that helps. God bless and be careful.
Aug 06, 2014 | Honeywell RTH6350D1000 5/2Day Prog...
Replacing a janitrol hpt 18-60 with a Filtrete 3m-22
What is the question that you have about this? What is the make and model of the hvac unit that it is running?
Apr 21, 2013 | Filtrete Thermostat. 7-Day Digital...
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
Is there an eternal fuse?
There is a GFI on the bottom right hand corner of the heater. It is a black box with 5 wires on the bottom in this order: blue, white, green ground, black, and white. The voltage across the blue/white should be about 100VAC and the voltage across the black/white should also be 100VAC. If the black/white isn't registering any voltage, the gfi is tripped.
The GFI typically trips due to moisture in the unit; however, it can also be fried if there was a voltage surge while you were gone. Use a hair dryer to dry up any moisture inside the unit, specifically around the GFI. If the water is pooling or you see a visible drip coming from the top of the heater, you heat exchanger is probably leaking and needs to be replaced.
If you have voltage on both sides of your gfi, check the voltage at the remote terminals. You should have 15VDC. If there is no voltage, you circuit board is damaged and needs to be replaced. If there is voltage at the remote terminals but no display on your remote, then check your remote wiring.
Aug 01, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
Wiring an electric water heater
Hello,You are correct! Black/blue=black & Yellow=white 220volt single phase power.There are 3 wires for 3 phase power connection NOT the case in a home.Also an "off peak"timer option would use (black) only controlling the bottom element and (blue) controlling the top element.
Apr 21, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I need to know what wires go to each marking
com=common= [ L ](live)same, the one that kills you. =red/brown N - neutral=black/blue Earth=green or green&yellow striped old colours= red, black, & green. new colours= brown, blue & green/yellow. L,N E.......... If you are uncertain of your abilities to wire up ,ask a competent electrician .........your life is worth more than £50.00.
Mar 08, 2010 | Water Heaters
RTO American Heat Tankless Electric Water Heater Logo
138 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
