Question about Garden
We have a husqvana 350 chainsaw, its got a new chain, new bar, new spark plug etc. when we used it, it was cutting small wood fine but any bigger than about 12" diameter it would cut on a angle, weve gone through manuals and all is fine by them, so WHY?
    Brigadier General:
  • 4,088 Answers
Usually, angled cutting is caused by heavy wear of the chain groove on the bar as well as the outer edges of the top and bottom of the bar which flare out when worn (file the extra metal off @ about 45 degrees). With all-new components, chain tooth shape may be incorrect (usually caused by faulty filing technique) due to a manufacturing defect. Make sure the chain is properly tensioned--it should be tight to the bar, but able to be turned by hand. Hope this helps!
Posted on Aug 08, 2010
What size bar and chain go on this for general crosscut work
the bar is determined by the engine capacity
small 35 cc engines run 350- 450 mm bar
bigger the engine the bigger the bar
as for the chain
the bigger the bar the bigger the pitch of the chain
talk with a shop that sells chain saws ( sthil--Mccolluck etc) and get the chain and bar suitable for the motor size
Nov 20, 2015 | Garden
Mt999 chainsaw. Brand new. Not cutting through wood although blade rotating. Just seems to be burning wood.
If it's all brand new, then sounds like you have the chain on backwards. The angled parts of the cutters should face forward while on the top of the bar.
Mar 16, 2014 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How to replace chainsaw chain
The bar is usually clamped with two hex nuts, you usually need to remove them, this allows the chain cover to come away, then wind back the tension adjusting screw ( with a flat blade screwdriver on a Husqvana other brands may be different ) back until the chain is loose enough to come off, the bar will also come off at this point.
It is a good opportunity to give everything a good clean at this stage and make sure the oil ways to the bar are clean and not blocked with wood dust, check the nose wheel on the bar spins freely and maybe grease it.
Put the new chain over the drive pulley the same way as the old chain came off, line it up in the bar slot and if you have the tension adjust wound back far enough for a new chain the bar will just flop over the two clamp bolts, replace the cover, and just do the nuts up finger tight so the tension adjust can be wound up to take the slack out of the chain.... not too tight ! it should still spin by hand without too much friction and you should be able to lift a link up half way out of the slot in the middle of the bar with your fingers.
Check the oil is getting to the chain by running at full speed with the end of the bar held just above a flat piece of clean wood, it should throw off a faint line of oil from the chain onto the wood.
Keep your chain sharp...
Happy sawing !
Nov 26, 2013 | Garden
I have purchased Poulon pro 42cc 18 inch chainsaw. I am extremely satisfied with my chainsaw until now. I have only owned it for about two months. I only used it maybe 10 times for easy tasks. my chainsaw...
The chain needs sharpened or replaced. You can purchase the tools from any hardware store, and sharpen the chain yourself in about 15 minutes. Don't worry, your saw is just fine!
Sep 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Are tungsten saw blades worth having if so were can i get one i have a husqvana 18" bar
Depends on what you are cutting (really dirty wood, railway sleepers etc ) they are expensive, and a problem to sharpen, i personally think it is not worth it, they are used a lot on rescue machines where cost is not an issue.
Apr 23, 2011 | Husqvarna Garden
Chainsaw is smoking excessively when in use
White smoke is usually associated with burning antifreeze in an automobile engine, but in this case, trying to cut wet wood might be suspect. The chain must be properly sharpened and the teeth cut toward you on the bottom run of chain. When the chain is properly adjusted, it should not droop from the lower edge of the bar, but no so tight that you can't turn it by hand. Forcing a poor cutting chain into the kerf will overheat the chain and cause it to become loose quickly. Hope this helps!
May 29, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I cut mostly hard woods, oak, hickory etc. I just
Have the chain professionally sharpened (Stihl or Husqvarna) at a saw retailer (take your saw). While there ask them to verify the gauge of the bar and chain are the same. When you return to pick-up your chain bring a few pieces of wood. Ask them to make a few cookies with your saw. Please reply with the result.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 28, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainsaw chain came off/is loose
You need to tighten the chain, and or remove and reinstall the chain depending on whether or not it has come off the drive wheel. The chain drive is on the right hand side of the saw, and there are either two nuts (about 1/2 inch or 13mm) holding the chain on, or there is a little half round handle you can use to tighten the chain after it is on the drive wheel properly. The saws with the two nuts on them have a small flat blade screw on the backside on the bar that you tighten the chain with. And to make things more confusing, some of the newer bars have a round hole in them, that after you loosen the two bolts, you stick a screwdriver in the hole and turn it clockwise to tighten the bar, then you re tighten the 2 nuts.
Since from your description that it wont engage to cut, you will have to remove and reinstall the chain since it is loose from the drive wheel. Clean out all the wood chips, etc in the drive wheel area before you reinstall the chain, make sure it is not on backwards and sharpen and oil it before you use it. Rick
Apr 11, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Engine cuts out
You probably have a fuel line that is cracked or has a hole in it of some sort. You should be able to take off the top cover and inspect these lines. If this is the problem, replace with new line & should work just fine. Let me know how it goes.
Mar 05, 2009 | Husqvarna Chain Saw 20" Bar
Husqvana electric chainsaw
Hi.
maybe its not sharper enough to cut those things that u r trying to cut.
check the saw tooth and use the chainsaw sharpener if u don't know how to make ur chainsaw sharpener take a look on this link.
click here.
i will fix u but you should rate me deal??
Aug 18, 2008 | Electrical Supplies
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
