Question about Polaroid FLM-3201 Television
The picture goes to gray after an hour or so. Sound still works, but no picture. Picture starts to go bad...then goes gray. Is this a heat issue? Work good for about one hour...then goes gray.
  • 11,361 Answers
When it goes gray, means that the T-CON goes bad after warm up or it does not receive the 12vdc feeding it from the main board, or the main board is bad, try running the TV with the back open with small fan blowing in the back, otherwise you can get a can of cold spray for electronics troubleshooting fro Radio Shack or repia shop and try cooling the T-CON bord or the main logic board with it to see will the pictures come back on. Also check the power supply for bad DC filter caps.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Aug 08, 2010
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
TV COMES ON NO PICTURE OR SOUND
If screen is gray glowing, the T-CON is bad or it is not getting the 12vdc from the logic board. You may have problem with logic board but do some voltage checking first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 28, 2010 | Vizio L37 Television
Samsung lcd le27s7 screening problem
The problem with your lcd monitor is that the picture board of your lcd monitor is faulty that is why it power on for one second goes gray and finally black with only sound.
Since the power led button is on and it still give sound but no display, it means the picture board of your monitor is bad.
All you need to do is to take the lcd monitor to any local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix all alone in other to complicate issue.
Take care
May 02, 2010 | Computers & Internet
Picture goes black, sound OK
is it under warranty, it could be the ysus or the panel
Apr 27, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Screen loses picture after several hours of use. Volume works, picture comes back on after several hours?
Look at the venting grills on the back to see if you see any white lights inside the TV whenthe picture goes out, if no light at all, then the backlight inverter board may be going bad when it heats up, or it can be the power supply that supplys the power to the inverter board is bad. Take a look at the power supply to see if it has any bad capacitors, that is the easiest thing to do.
Please post back what you find.
Nov 11, 2009 | Insignia IS-LCDTV32 32 in. Television
NO PICTURE AND SWITCHING ITSELF OFF, SOUND BUT NO PICTURE
Most likely you have a power supply problem. Capacitors go bad in the power supply causing voltages to fluctuate when the set is trying to start. Have a repair shop check it out.
Oct 14, 2009 | Philips 42PF9630A 42 in. Plasma Television
Problem with Picture and sound after about 40 mins playing time.
the unit is over heating. Make sure you hear the fan come on. Also make sure the unit is in a spot where it gets ventilation. They get real hot and need to disapate heat or the mother board burns out.
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
Toshiba 62hm94 projection tv
Sounds like the lamp is going bad. They heat up, and shut down. Then when they cool off they start back up.
Jul 09, 2008 | Televison & Video
Goes from good picture to gray and small lines then back to good picture
Check capacitors in the power supply. They dry out with heat and most of time they bulge on the tops. Replacing them should fix the problem. The power supply voltage varies causing the problem you describe. Let me know what happens.
Mar 02, 2008 | Televison & Video
Polaroid FLM-3201 Television Logo
105 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
