Is there some adaptor to adapt a floppy drive with an IDE style connector to either type of USB connection? Be it a regular USB 2.0 or an internal type USB connection on a motherboard (preferable)? I currently have an external type floppy drive with USB, they don't mount so well in comp case.
    Brigadier General:
  • 4,044 Answers
Not that I have ever heard of. You could get a Floppy drive bracket and remove the floppy from the case and install it that way. It's just a regular Floppy connected to an adapter inside that case that turns it into a Portable. Like the stand alone backup drives everyone buys today. You remove the hard drive from the casing and it mounts like any other drive.
Posted on Aug 08, 2010
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
Wd50000aakb make into a external usb
AU $8.10 free postage worldwide
DID this HDD (Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive) can atach in ASUS K8U-X, Thank you, Nikola
ASUS K8U-X - motherboard - ATX - Socket 754 - ALi M1689
1.0 x PCI - Socket 754,
2.0 x Processor - DIMM 184-pin,
4.0 x AGP 8x,
1.0 x Memory
  • Storage Interfaces ATA-133 - connector(s): 2 x 7pin Serial ATA - RAID 0 / RAID 1 / JBOD,
    Serial ATA-150 - connector(s): 2 x 40pin IDC
  • Interfaces 1.0 x Keyboard - Floppy interface - RJ-45,
    1.0 x Hi-Speed USB - SPDIF output - 6 pin mini-DIN (PS/2 style),
    4.0 x Network - Generic - 34 pin IDC,
    1.0 x Audio - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
    1.0 x Audio - Ethernet 10Base-T/100Base-TX - 9 pin D-Sub (DB-9),
    1.0 x Parallel - Generic - 4 pin USB Type A,
    1.0 x Serial - RS-232 - 6 pin mini-DIN (PS/2 style),
    1.0 x Storage,
    Mouse
  • Power Connectors 20-pin main power connector,
    4-pin ATX12V connector
  • as long as the PSU and motherboards power and lead connections are the same as the hard drive
    hope this helps
    May 10, 2011 | ASUS K8U-X Motherboard
    What kind of ac adaptor does the drive need
    The following link shown are for a hard drive with a 3.5" IDE connection and a PPA International USB to IDE adapter kit. If you have a different type of drive or a different adapter, please refer to the manufacturer's directions for how to properly power and connect your devices.
    http://www.ehow.com/how_4870940_drive-hit-virus-via-usb.html
    Mar 01, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
    Hi, I am trying to work out what kind of connector I need for my old HHD's (I have 2) I am thinking of buying an outside casing so that I can transfer my old data from these two drives to my current HDD,...
    Hi. Thanks for your question.
    Your Hard drives connection type is IDE. You can but adapter for your hard drives to connect them via USB port to your current machine. This is link to one of adapters like this on ebay so you can have a look at what I mean http://cgi.ebay.com/USB-2-0-IDE-SATA-S-ATA-2-5-3-5-5-25-Adapter-Cable-/280501660830?pt=LH_DefaultDomain_0&hash=item414f33ac9e#ht_3091wt_1139
    Buying adapter like this would mean that you could still use your drives and keep files on them. Use them as external drives. Only connect when you need them. I hope this helped you. Please do not hesitate to ask more questions if this is needed.
    Dec 06, 2010 | Samsung SpinPoint V60 SV0813H 80 GB...
    Hard drive adaptor
    Your laptop HDD uses a newer connection type called SATA. The one you are used to using is called IDE. They do make adapters to go from one to the other but they are hard to find and not very reliable (sometimes just dont work).
    You can find a 2.5" (laptop size) hard drive enclosure for SATA to USB at almost any electronics store.
    Double check your motherboard (on your desktop if thats what you are using to read the drive) for SATA connectors on it. Many computers have been using SATA almost as a standard since about 2004-2005, but some may not still have it.
    The reason for the new type of connection is faster data transfer speeds.
    To look at the differences, click the link below:
    http://jekkilekki.files.wordpress.com/2009/06/sata-ide-laptop-hard-drive.jpg
    Oct 16, 2009 | Toshiba Satellite P105-S6104 Notebook
    Hard drive does not have pins but has tab style plug
    What you used to have is a called a Parallel ATA (IDE) drive. What I beleive you bought is a Serial ATA drive, thus the difference in the cables and connectors.
    Here is a link to an example of the adaptor you asked about, but my concern would be that when you add the adaptor to the drive, it would be too large for the enclosure.
    Sep 18, 2009 | Toshiba Satellite A135-S4527 Notebook
    I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
    SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
    1 external connection kit
    1 internal connection kit
    The internal connect kit consists of 1 red USB connector cable
    and 1 internal white male molex connector to SATA female power connector
    ( 1 yellow wire , 2 black wires , 1 red wire )
    the external connect kit
    consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
    Selah :-)
    Sep 14, 2008 | Computers & Internet
    Hp nx9110 laptop
    There are several ways you can check if you have a working hard drive in your laptop.
    1. Get into the BIOS configuration of your laptop, you may be able to see your laptop's configuration, and maybe even see your hard disk. This means your computer has been configured to work with the hard disk, but does not mean the hard disk is OK
    2. If your laptop has a floppy disk attached then you can use a boot floppy disk and boot up in DOS. Then you can then run FDISK and then display the hard disk. If FDISK does not detect a hard disk the it is most likely dead.
    3. If you can get access to a USB hard drive adapter cable or an IDE adapter cable that you can connect to a working computer's secondary IDE controller. THEN
    Remove your laptop drive and connect and connect it to the USB adaptor or an IDE cable, (make sure you connect the drive correctly to the connector) then connect it to a working computer.
    If you use an USB adapter, when you connect it to a working compute with XP or Vista operating system, and if the hard drive is OK then you will see the contents of the laptop hard drive.
    If you connect the IDE cable to the secondary contriller and then boot up the working computer with XP or Vista operating system, if the laptop drive is OK you should see the contents of the laptop hard drive.
    If you don't see the hard drive, then most likelt it is dead.
    Jul 27, 2008 | HP Compaq Business NX9110 Notebook
    Imation SD-USB-M2 SuperDisk USB(MAC)
    Sounds like a dead (or jammed) motor -- the one that spins the media. It's relatively easy to open the case, disconnect the USB-to-IDE interface adapter from the 40-pin IDE connector, and go onto eBay to find any "internal" or "external" LS-120 device, and swap it in, to replace the "not-spinning" device.
    Jan 26, 2008 | Imation (01946) External Floppy Drive
    Computers & Internet Logo
    121 people viewed this question
    David Payne
    David Payne
