Question about Ovens
Hello, My Candy oven FL 605 X was working fine yesterday. Today I went to switch it on and nothing happenned,no heating, no convecion, no grill, no on light working. Only the clowck and timer are working so there is electricity to the oven. Have you any ideas what I could do to fix it? thanks and waiting for your advice. Caroline
SOURCE: Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
Posted on Jan 20, 2008
SOURCE: Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Posted on Apr 17, 2008
SOURCE: candy oven
you either have wire,s crossed or you need a new selector switch
Posted on Nov 13, 2008
  • 4 Answers
SOURCE: belling oven
you will have to replace the main oven element...
Posted on Dec 19, 2008
  • 4 Answers
SOURCE: lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Posted on Jan 07, 2009
My Candy FPP6071X oven won't heat up. The grill and everything else is working fine. Any suggestions?
As you can see on the electrical diagram grill heating element (RG) work alone or in seria with inner lower heating element (RI) and based on the your statement, I conclude that does not work lower heater (RD). So, you should check resistance of lower heater (RD), contacts of change over switch (P7-7 and P6-6) and wiring. By the way, both heater (RI + RD) is integrated into a single heating element.
Dado
Feb 22, 2015 | Candy Ovens
Candy oven FL134 n uk will not heat up! (Since I had a power cut) The grill is working fine
I think that should be checked round heating element (RC) and change over switch (CO).
Dado
Feb 13, 2015 | Candy Ovens
Oven not heating but grill still working
Call an electrician and ask them to check your 'Bake' elements.
If the elements are working, then check the oven function selector switch to make sure all of the contacts are working.
Apr 15, 2014 | Candy Ovens
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 | Ovens
Candy oven broken
Poor quality connectors or crimped wires I would think.
Sep 16, 2017 | Ovens
Lamona LAM 4400 oven not switching on
may be an internal fuse / wire burnt off oven control as nothing works
Nov 10, 2013 | Ovens
Electrolux EOU5330X Ultrafan Electric Double Oven -
Sounds to me like the lower element shorted and tripped the breaker as it burned out. If you're handy at electrical troubleshooting that's where I'd start - comparing ohmmeter readings between the bad element and the one that works.
A wire short to the chassis would have a similar set of symptoms and be easier to find and fix.
Beyond that, you need a service tech.
Sep 03, 2017 | Electrolux EOU5330X Ultrafan Electric...
My candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Mar 28, 2010 | Ovens
Oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
Sep 25, 2009 | Ovens
Candy F254/3X single fan oven, grill works, oven doesn't.
If fan is working o/k, then you need to fit a new oven element
Please`rate my solution.
Thanks.
Aug 24, 2009 | Candy F248P Electric Single Oven
Ovens Logo
80 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
