Question about Brother Office Equipment & Supplies
I believe there is a sheet of paper stuck in my Brother HL-2040 laser printer. I am unable to remove the toner cartridge to get the paper out; it seems to be stuck. What should I do? Thank you.
I knew I had to take out the toner cartridge but I couldn't remember if it was one piece or two. I went to over a dozen websites before I found some details beyond "Take out the cartridge." However the image was not clear. I asked for help from my wife, who knows less aobut computers than I do. She said, "It's definitely two pieces," and took the toner cartridge out, whereupon I removed the paper stuck in there and put the toner cartridge back in. Moral of the story: When even the instructions fail, ask you wife. Thank you, dear!
Posted on May 26, 2008
Paper jam. Sheet printed but didn't pass through the rollers
  • Remove the paper tray completely by pulling it out towards you.
  • Now pull the jammed/stuck paper out gently.
  • If you cannot remove the paper by the above procedures,open the printers front cover to access the cartridges assembly.
  • Pull the cartridges assembly gently and slowly.This will come out together with the jammed paper.
  • If jam not cleared,open the back cover and pull the tab outwards to access the fuser unit.Remove the stuck papers here.
  • Hope this helps.Thanks!
Oct 31, 2011 | Brother HL-2040 Laser Printer
How do I remove the toner cartridge on HL 2040 ?
Open front cover and pull out the toner cartridge with drum unit. To release toner cartridge from drum unit just push blue lever down and lift up toner cartridge.
Feb 01, 2011 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
How do you get the toner cartridge out of brother 2040? we have paper stuck under it
The toner and drum come out together, open the front door and pull the handle in the center straight out toward the front. The toner lifts off of the drum by pushing the blue lever on the right or left rear side and lift up and out. You need to inspect the underside of the toner and drum for paper scraps that could cause jams.
Nov 12, 2009 | Brother HL-2040 Laser Printer
Paper stuck in the printer. How canI get it from there?
In this printer maximum paper path can be check once you remove toner cartridge and if you don’t find any paper in this area check rear door and you may find paper below cover area ,
paper can be access and removed
Nov 07, 2009 | Brother HL-2040 Laser Printer
I have paper stuck in my Brother HL-2040 but cannoy see it. How do I open up printer to get the paper out?
there should be latches on back side and on the bottom side of the printer. when you unlock it and open you will be able to see the paper.Usually if you open cover just as to remove cartridge you should see paper jammed
Sep 23, 2009 | Brother HL-2040 Laser Printer
Won't feed paper
It has toner? if not replace new one. If it has toner then try to remove the catridge and place it again. This might help you.
Mar 02, 2009 | Brother HL-2040 Laser Printer
Brother 2040 laser printer
You just lightly pull on the sheet of paper from both corners. There is no release valve.
Jul 14, 2008 | Brother HL-2040 Laser Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
Paper light on...!!
Turn the printer off. Take out the toner drum and cartridge. Remove the toner cartridge by pressing on the blue lever on the left side. Check for paper. Replace the cartridge. At the rear of the toner drum is a blue slide lever on the right side for cleaning the corona wire. Move the lever back and forth, left and right, about 30 times. Reset lever to far right side with arrows lining up. Set the drum and cartridge aside. Remove the paper tray and look inside for a jammed sheet of paper. Flip the back lid down and check for paper. Snap the back lid up, replace the paper tray, and replace the drum and toner cartridge. Turn the printer on. Press the ready button 3 times quickly. It should print a specifications sheet. If it does, try printing from your computer. If this did not help, Brother tech support is 1-800-276-7746. Robi
Nov 10, 2006 | Brother HL-2040 Laser Printer
85 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
