Question about Hoover Vacuums
Hoover u5472-940 has a squeaky back wheel. how do I fix it?
  • 78 Answers
Use lithium greese when needed
Posted on Mar 29, 2009
How do I fix the wheels back in my Vax upright hoover
You need to list the model number to this vacuum and be more specific with your question.
'fix the wheels back' is very unclear.
Feb 03, 2015 | VAX Appliances Vax X3 Bagless Upright...
Troubleshooting dyson dc01 upright hoover
If you are referring to the bearing cover on the wheel, this appears to be purely cosmetic. The disc is clipped onto the wheel and can easily be replaced IF you have not broken off the latches.
Aug 19, 2014 | Dyson Vacuums
Cord rewind hoover s3765
Remove the 5 Phillips-head screws carefully without stripping the heads. There are 2 at the front bottom, 2 at the top back (above the wheels), and 1 at the back beneath the dustbin. After the screws are loosened/removed, you can remove the top cover of the vacuum (be careful with the attached wiring harness). Then remove the black plastic cover over the cord rewind wheel, and you can easily remove the wheel. Pull the cord out a bit to give yourself some slack. You should be able to free the jammed cord and then reassemble the vac.
Nov 14, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Hoover front wheels replacement
on the wheel assembly you will see on each end the studs with the flat ends on them,slide the studs in the slots and fold wheels forward and push in.in the middle at the front of the wheels you will see a flat catch ,push it up into the base right behind the brush roller and it will snap in
Oct 04, 2008 | Hoover Elite U5061-900 Bagged Upright...
How to fix wheels on hoover vaccum cleaner
i cant get the back wheels off my mach 3 hoover vacuum can anyone help?
Jul 14, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Replacing leaf spring Hoover wheels
If people are still having this problem, please post here and I will take a picture of the correct placement for the metal clip.
Apr 07, 2008 | Hoover U5227-930 Elite Upright Vacuum
How to install front wheel assembly on Hoover Bagless windtunnel vaccuum
There is a spot that sticks up on the holder for the wheels, the hole in the spring goes there, then it fits between the holder and the base asm.04f5295.jpg
Feb 24, 2008 | Hoover U5753-900 WindTunnel Bagless...
Wheel carrier spring
What is the correct model number???
Feb 23, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
104 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
