Question about KitchenAid KESC307 Electric Kitchen Range
Kitchenaid kesc307bwh4 range had been stored for a year and when reinstalling the control panel will not work. it gives a error code F5:E3.
    Genius:
  • 1,035 Answers
Hi. I provided you a manual/documentation for you Kitchen Range. Please click here. Below are common error codes or your unit.
F 5 = Latch Subsystem Failure. Check for proper latch movement, switch actuation, and
clearance between the latch and door.
E0 = Latch switch does not agree with door switch (i.e. Iatch in locked position with
door open).
E1 = Latch will not lock.
E3 = Loss of ground or L1 to N is reversed. Check to make sure that the voltage from
L1 to ground is 120-volts AC.
E5 = Self-clean temperature set point is not reached within the required time range
(usually 30 - 45 minutes).
E7 = Latch will not unlock.
All the best!
Posted on Aug 08, 2010
Fix f5 e 1
F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My kitchenaid range KESC307HBS door will not unlock code F5 E3
Hi ad welcome to FixYa, I am Kelly
Here is the service manual:
http://appliancedigest.com/index.php?/files/file/242-whirlpool-kac-34-kitchenaid-self-cleaning-slide-in-electric-range-service-manual You have to join the site to get the manual but of all sites this one is a gold mine of information. I am sending this link now and will respond again after my almost 3 hour manual download of the manual. I have to read the manaul myself before responding. My intial thoughts are the following: Possible door lock failure, an oven sensor has failed or a high limit thermostat has failed. I will resond with the code F5 E3 data after the manual completes. Thanks for choosing FixYa,
Kelly
Jun 20, 2011 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Aid range Breaker always tripping ERROR F5:E3
The elements or a hot wire feeding the control switches has been bumped and is grounded. You can probably find it with a thorough visual inspection. Look very close at the wiring and look for something pinched or touching metal.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 14, 2009 | KitchenAid KESC307 Electric Kitchen Range
F5-E3 CODE
Lbenes:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, NAR_Customer_Solutions@kitchenaid.com, with your name, Review ID Number (), phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank You
KitchenAid® Social Media Relations
Mar 06, 2018 | Whirlpool RF378 Electric Kitchen Range
Kitchenaide range trouble codes
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@@@
Mar 13, 2009 | KitchenAid KESA907PSS Electric Kitchen...
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
OVEN
5a66, actually code for "sabbath mode", as far as f5 e3 there is no code listed for that other then f5(refers to an input code) so possible that when you get stove out of sabbath mode youllbe fine, reffered to in your user manual pg 19 , heres a link if to a manual if needed.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209757452.pdf
Apr 07, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Error Code F1:E3
reprogram the control board as following:press buttons on range
power off wait 5 sec
power on wait 5 sec
convection broil
clean
backed goods
stop time
190
timer set
start button 12 times(it will go through all the settings)
Mar 17, 2008 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
128 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
