Question about Karcher 2500 PSI Pressure Washer
Carburator is gummed up I can remove the carburator but after that im lost I removed the screw from the bottom of the cup drained the old gas shot some carb cleaner in there opened the gas line put the screw back in numerous times wont start regapped the spark plug and cleaned it won't start only has been used about five hours my buddy didn,t run the old gas out of it two years ago before winter it's a type 5 manual choke/fixed throttle
    Top Expert:
  • Karcher Master
  • 53,101 Answers
Leaving fuel in a bowl will cause corrosion in the jets and jam the needle and seat operation
take the carby off the machine and go to a shop that can overhaul the unit
Posted on Jun 29, 2017
4 Suggested Answers
  • 18 Answers
SOURCE: Karcher 2400R
You have a poor signal to the spark plug usually caused by a rusty fly wheel found underneath the pullcord casing. clean it with releasing ajent such as wd 40. common when not in use for a while.
Posted on Sep 19, 2008
  • 92 Answers
SOURCE: % hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Regards,
MG.
Posted on Nov 05, 2008
wmpcs
  • 100 Answers
SOURCE: Honda GC 160 Engine, I had the carb replaced about
This really sounds like a carb problem, good to hear that you are taking the carb all the way off and soaking it, this is the best way to clean a carb. I don't think it would be the fuel pump, they either work or they don't. I would check the governer springs and linkages, if one of these is hung up on something it would cause the problems the you have identified. Also, when you re-install the carb make sure that you have all the gaskets installed, it is easy to forget one and that will cause the engine to **** air and make the whole engine run like ****.
Posted on Oct 21, 2010
Old gas bike been setting for years
I would drain old gas, replace with good..old gas can gum up carbs, should drain bowls on carbs also, there should be a screw on bottom of carbs(dont remove screw just loosen till gas pores out)
Apr 13, 2013 | 1992 Suzuki GSX 600 F (Katana)
How do you remove the airbox and carbs on a 1996 Ducati 900ss?
Hi, Anonymous if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
1. If your battery was 3 years or older when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or better, any readings in the 11 volt range you need to do a proper load test on the battery and replace as necessary, any readings in the 10 volt range you have a dead cell and replace the battery.
4. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
5. Remove your air cleaner and clean and re-oil per Mfg. specifications.
6. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
7. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
8. Replace spark plug with a new one and check for spark.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Carb Removal and Cleaning Ducati ms The Ultimate Ducati Forum
R6 Remove tank carbs Tools needed part 1
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 02, 2012 | Ducati 900 SS Motorcycles
Mower starts but wont keep going.it has petrol and oil,it had carberetta serviced last year.
You might have the same problem as had last year, did you burn all the old gas out last year before storing for season? If not you will have to drain old out and probably remove and clean your carbureator it probably gummed or varnished up from old gas, hope this helps you
Apr 25, 2011 | Garden
How do i drain old gas from the motorcycle
you will need to remove ur seat in order to get to the bolt or clip down that holds the rear of the petrol tank to frame.make sure the fuel tap is off & remove the fuel line going from tank to carburator then remove tank & empty the old gas out.there should also be a drain bung/bolt on bottom of ur carburator bowl,undo this let all gas empty out,then re-tighten & then reverse steps to put tank back on.Fill with fresh gas try start,check for any leaks & should be good to go!
Jan 04, 2011 | 2007 Yamaha XT 125 X
Water in my Quad Bike engine, How do i remove all of it ?
You do not need to tear into the engine. Just remove the drain screw (or drain plug) from the carb float bowl and drain the carb. Remove the tank and dump it out. flush it with a bit more gas. Remount the tank then fill with gas. Drain a cup of gas and check for water in the bottom of the cup. Keep draining until no water is in the cup.
You may need to remove and clean the carb. Sitting for a year can allow gas to dry and form varnish that can plug up the jets. ESPECIALLY if the gas valve was left on.
A “very helpful” rating on this answer? Thanks!
Jul 02, 2009 | 2004 Factory bike Chrono SM 250
Hi I have rebuilt the bike with a rebore due to some scoring and fitted new crank seals, the bike has only done 1200 miles from new, it runs real bad and has lots of fuel blowing back thru the carb. Any...
Your carb is gummed up from old fuel. ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Your gas tank should be removed , dumped and flushed out. Install an in-line fuel filter. If the tank is badly rusted, Google kreem fuel tank liner or go to www.http://www.4secondsflat.com/Fuel_Tank_Sealer.html I
Drain the carburetor. There should be a plug on the bottom or a bolt on the lower side of the carb float bowl. Remove it then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine.
After sitting for 24 years the crank bearings may be in bad shape. Remove the left case cover and lift the flywheel up and down and left and right. The flywheel should be rock solid with no movement at all.
This shows a 1983 carb. Yours will be very similar.
Jun 25, 2009 | 1985 kawasaki KE 125
Lost speed
FOR EACH CARB >
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
Apr 25, 2009 | Honda CB 250 Motorcycles
Im working on an 2005 honda trx450r four wheeler. i can not get it to fire. im getting fuel to the carb but not to the motor. do you possibly know what would cause that?
Get a new stock NGK sparkplug. Check for spark. I am a bit unclear if you have spark or not. Got a good battery? Any kill switches on?
Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Drain a cup of gas from the tank. Any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Check the throttle slide. Does the slide go up and down when you turn the throttle?
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install the new NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Be sure the bolts are tight. Let the float bowl fill then start the engine. Set the idle speed with the idle screw. This process should get you back on the road.
Please rate this solution. Thanks slik_105!
Apr 04, 2009 | 2005 Honda CRF 450 R
Early 80's rm 125 carb help
The 'port' questions should be answered by the following.
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. Set the idle speed with the idle screw. This process should get you back on the road.
Please rate this solution. Thanks thejoker1879!
Mar 31, 2009 | Suzuki RM 125 Motorcycles
Location of carburator
The carb is the big thing bolted to the back side of the cylinder. I assume you are having carb problems. Turn off the gas at the tank. Next, on the side of the carb near the very bottom is a large screw. Remove the screw and the gas and any water in the float bowl will drain out. Put the screw back in, turn the gas back on, and see if the problem has gone away.
If not then turn the gas off again and drain the carb again. Next remove the water trap bowl behind the gas valve. Clean the bowl and put it back on. Turn the gas back on, wait a minute for the float bowl to fill and then see if the problem has gone away.
Let me know if this fixes the problem. Just post a comment.
Mar 28, 2009 | 2003 Yamaha TT-R 225
Karcher 2500 PSI Pressure Washer Logo
63 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
