Question about Samsung DVD-VR330 VCR and DVD Recorder
I have tried to play a dvd that i have played several times in the past, and get an error code that says. Disc cannot be played, please check the disc. Disc works fine on other DVD players and on my computer.
  • eagle338
    eagle338 Aug 08, 2010
    Hi this is eagle338. Did the lens cleaner work?
  • shuldahome2 Aug 08, 2010
    No the dics cleaner did not work. The dvd gave me the same error code,and would not play the dic cleaner.
  • 4,889 Answers
In that case I am afraid you are gonna have to get the lens/laser assembly replaced. How old is the unit?
Posted on Aug 08, 2010
Testimonial: "Very helpful, Good to know that there is someone out there that knows how to fix these things. I won't hesitate to you this WEB site in the future. "
    I discovered that I had purchased the wrong DVD cleaner. the first one I got was for Blue Ray, I went back to the store and got the right one, and the DVD works fine after I cleaned it.
    Thanks again
SOURCE: DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
http://forum.ecoustics.com/bbs/messages/15118/130292.html
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
Posted on Feb 14, 2008
SOURCE: Unknown disc error
In my dvdr630vr plays only audio cd`s. Same problem?
Posted on Feb 01, 2008
satavlad
  • 405 Answers
SOURCE: ERROR H02
Spindle motor in DVD mechanism require replacement, not practical to repair, just buy new one, upconverting DVD player would cost you less then repair of your old one.
Posted on Dec 01, 2009
  • 25 Answers
SOURCE: DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Posted on Feb 18, 2010
walesarumi
  • 6993 Answers
SOURCE: my dvd player plays cds but wont play dvds says
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Posted on Apr 22, 2010
I am going out of my mind trying to dub VHS to DVD on my new Toshiba DVR620. Please help!
I have a Toshiba HDD&DVD vcr RD-XV48DTKB will not accept disc or play any disc have tried several makes even new ones it just loads then says error cannot play eject will not play or record HELP
Jan 22, 2011 | Toshiba DVR620 DVD Recorder/VCR
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 18, 2010 | Microsoft Xbox 360 Console
Check disc error
When you get a please check disc error when playing a DVD in your DVD machine, this is a signal that the lens of the DVD machine is getting weaker. I would ask you to try and play a CD in that machine. If it plays that means the lens of your DVD machine is weak. You have to change or purchase a new DVD machine.
Oct 17, 2009 | Marantz DVD-930 DVD Player
WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
May 23, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
When trying to play DVDs the words unknown disc title appears. Even after several attempts with various DVDs we havent had any success.
have u tried cleaning the hea of ur dvd player?after using a dvd player or cd player for long times of continous play say 6 months or if u play too many scratched discs and u dont clean the head of the player it starts skipping the disc or many a times dosnt recognise the disc so it'll give u errors like "Unknown Disc", "Disk Error" etc so i would really recommend u to clean its head using a dvd head cleaner cd.. its easily available in the video stores or malls.. u can purchase any dvd head cleaner cuz there are number of manufatcures for this. im sure this would solve ur issue.
PLEASE DO RATE ME,WOULD REALLY APPRECIATE IT
THANX
Oct 06, 2008 | Philips Televison & Video
Optiarc DVD RW AD-5170A ATA not writing DVDs
sounds like your file is to large by the time it writes in and out or the disks a not to great
Mar 02, 2008 | Computers & Internet
DVD player will not play it's e-Machine
have you tried
reinstalling the driver?
using a different dvd. (might be a different regonal setting.
check device manager for any problems also double click on your cd device in the device manager and see if there is an error code 41. very common this is a registry conflict easy to fix.
let me know how things go.
nick.
Dec 07, 2007 | Medion M3 Composer 5200 PC Desktop
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Oct 06, 2007 | Sony DAV-DZ100 System
Samsung DVD-VR330 VCR and DVD Recorder Logo
619 people viewed this question
Jerry Greenberg
Jerry Greenberg
