Lg tv cf20d30 goes to standby mode intermittently every 30 to 60 secs after switching on.
  • Anonymous Mar 16, 2014
    lg tv cf20d30 goes to standby mode when i switching it on it never show a pic but turns to standby mode again.
    Genius:
  • Televison & ... Master
  • 1,689 Answers
Most likely there are some parts that have become thermo sensitive with age. Many times electrolytic capacitors become thermo sensitive as they ware down.
The parts that are going out of spec are probably causing some kind of fault that the set's uPC sees as a fault and puts the set in to protection.
The service tech will use a heat gun and liquid air also known as "freeze spray" to cool and heat the suspect components to trigger the fault, and then reverse it. Once the parts are found, they can be changed.
Jerry G.
Posted on Apr 27, 2008
When you switch on the tv it goes to standby mode, and when you press standby it turns on to a orange light then goes back to a red light, any idea whay this is happening ....
My Westinghouse LCD tv has the same lights on it It goes orange or red when there is no signal from that source... or while it is calibrating itself to the new frequency etc.
Oct 19, 2013 | LG 42PM3MV 42 in. PLASMA TV
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
When i plug my lg lcd tv in, it does not turn on, instead the standby light on the front of the tv flashes as if its coming on and then goes. i have tried plugging it back in many times but cannot find a...
Have you tried switching it on using the remote control for your TV? It appears your TV is on standby mode and only the remote might do the trick to get it to fully power on.
Post a feedback or update if this tip does not help you out.
Oct 12, 2017 | LG 32LX1D 32 in. LCD Television
Hi, i just purchased two LG LCD TV's the 26LD350 and the 32LD350 I'm worried that it does not have an off switch and only goes on to standby mode. you here alot about tv"s catching on fire because of this....
I have never heard of any LG TVs having a fire issue.
LG added this switch to help save electricity. "Going Green".
You see, this On/Off switch was added to kill the power to the TV when not in use. This switch stops the TV from consuming power by not giving it power to be in a “Stand-By” mode.
If your TV does not have this switch, you could simply unplug your TV to give you the added satisfaction it won’t catch fire.
I hope this information has helped.
Good Luck.
May 23, 2010 | LG Televison & Video
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
TV will not go into standby mode
You may have to unplug the tv from AC power for a few seconds and then reaaply the power! Or replace the small signal board.
Sep 13, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
TV, KV-TF21M80 TURN JUST A SEC AND BACK TO STANDBY
try to pull out first the vertical IC, then switch ON the TV,If the Tv is On it may be the Vertical IC problem change it. If Still the same before pulling out the V IC. check the low voltage side for any diode leak.
Sep 06, 2009 | Televison & Video
The screen went blanc and would not respond. When switched on, the set goes into standby mode and does not respond
hit the side of the tv and if you can get it to come good for a sec then you have dry joints on the main board.
hope this helps
Nov 26, 2008 | Televison & Video
LG CT-29K30EX 29" TV plugged
LG CT-29K30EX 29" TV - We have the same symptoms as described. If you are a person who is not afraid of opening the back cover of your TV and replacing parts inside. this tip is for you. Contact a service person if your not 100% sure. Its actually easy, it involves replacing a small capacitor in the power supply section. You don't need to troubleshoot coz i've done that for you for free. Find this capacitor in the power supply. C801 with a value of 100uf / 35V. De solder and replaced it with the same value or a much higher Voltage rating e.g. 50V. Done! your T.V. is alive again. - Rey Tilles - New Zealand
Apr 06, 2008 | LG Televison & Video
Televison & Video Logo
319 people viewed this question
Top Televison & Video Experts
