Question about RCA DRC8030N
Trying to record a home made video to hard drive but i keep getting message screen saying cannot record due to copy rights by owner
  • eguchi0723 Aug 11, 2010
    cannot record to hard drive or disk when i try i get screen that says cannot record material due to copy rights of owner
  • RCA Master
  • 12,061 Answers
Hi, yes well DRM is a real pain unfortunately there is NO way around this... I am sorry to say.
I am at a loss as to what to advice you to do?
One way would be to play the Video, and take a screen camera copy, then use that data to Burn to a DVD etc.
Or again, "Play" the Video and stream it out to a PC, copy it to a PC, and then burn to DVD?
www.dvdfab.com/dvd-to-dvd.htm
Software to overcome copyright above.
Please find below the master Google link, used to assist, have a look there for suitable software and explanations.
http://www.google.co.nz/search?num=100&hl=en&&sa=X&ei=ETRjTJTMNIL_8Ab_wqWMCQ&ved=0CBQQvwUoAQ&q=how+to+remove+copyright+from+movie%3F&spell=1
Posted on Aug 11, 2010
  • 4,889 Answers
Its a problem with your BOX. You should go to your account settings and choose the "allow recording" or something like that. I would suggest that you call the company that sold you the box and ask them how exactly to do this as sometimes there are a lot of settings have to be changed.
Posted on Aug 08, 2010
  • eagle338
    eagle338 Aug 11, 2010
    I told you what is logically feasible. Otherwise you can get me the make and model of the box and I will look up where the account settings option is on your device.
  • eguchi0723 Aug 12, 2010
    its a RCA DVD RECORDER WITH 80GB DVR MODEL DRC8030N
    THANKS
How do i fix my acer aspire 4720z when it says operating system not found
The operating system is stored on the hard drive. This message basically means that the system can't find the master boot record on the hard drive.
This could be due to a number of reasons:
The hard drive has failed
BIOS can't find the hard drive
Master boot record corrupted
Try booting the system and hit the key which will show the system setup/BIOS screen (delete key or one of the F keys).
Check here to see if the hard drive is listed. If it is then the BIOS is probably not the problem.
The next step would be to put your windows recovery CD in to the CD drive and start the system. At the welcome to setup screen, press R to open the recovery console, select the operating system you are using and press enter. This should start the recovery console. At the command prompt type: fixmbr and press enter. The system will attempt to copy a new master boot record to the hard drive. Follow on screen instructions to complete the process and reboot system. If this does not work, it will probably mean a new hard drive.
Mar 17, 2012 | Aspire Acer 4720-4538 Notebook PC
Errors burning to 1x to 16x DVD-R
I have had much luck recording on off brand 16X discs as follows:
1) Record a "dummy" program on the hard drive, need only about 15 or 20 seconds.
2) Put a blank disk in drive, and COPY that dummy program to disk. Do not finalize.
3) After a minute or so, window will come up and say "Cannot
complete copy."
4) Now while above window on screen, click HOME MENU, COPY, New program list, Select your movie/program to copy, go ahead and finalize, and START.
5) Think you'll find this is successful, however there might be some brands of blank disks that won't work.
6)Let me know if it works for ya. JGIDUSKO@CFL.RR.COM
Jul 04, 2008 | Pioneer DVR533HS DVD Recorder with 80GB...
AFTER 6 HRS RECORDING MESSAGE DISPLAYS NO MORE SPACE LEFT
It is true that the manual says it can record 100 or more hours...but that is at the lowest resolution. You can go to the menu screen and from there go to the recording properties and play around with different recording resolutions that best fit your recording needs. Also, the DVR uses a Hard Drive just as any computer does and within' time it becomes fragmented... that may cause it to record less hours even if you delete recordings. You can format the internal hard drive by going to the main menu screen and press and hold (for about 10 seconds) the OPEN and PLAY buttons on the unit (not the remote). At this time you should see the words FORMAT on the LCD screen and the unit will shut off. Keep in mind that formatting will erase everything on the hard drive so make sure you back up to DVD whatever you want to keep. Hope this helps.
Jun 23, 2008 | RCA DRC8030N
Recording from Sky+
could be possible that Sky TV is right protected therefore making it hard or impossible to record.
Jun 11, 2008 | Televison & Video
DVD-Rom drive doesn't work.
right click my computer .. manage.. storage.. disk management. unalocated. its totaly empty . create partition then format it ntfs and name the volume uhhhh USB160GB for easier to recognize
May 17, 2008 | Maxtor Hard Drive
Recording problem with LG RH266 Recorder.
If the DVD is copy right protected then it won't record. By this I mean, you can't simply rent a DVD at Blockbuster and transfer it to the Hard Drive (use a computer to do this instead). Try using a DVD that is not protected, like a home video or a cd with MP3s
Feb 26, 2008 | LG RH266 Recorder
TDK dvd+r home copied disc
check drive properties inorder to verify whether ur drive support +R dvd
Nov 30, 2007 | Computers & Internet
Recording disabled
guys hope you all found the solution like me who had same issue. if you noticed, it says about the aspect ratio and that means the formated disc aspect ratio is not compatible with the aspect ratio your camera need. so re-formating the dvd with right aspect ratio solved the problem quickly and we have peace.
bayaraa
Nov 24, 2007 | Sony Handycam CCD-TRV37 Camcorder
Owners manual
System will not record callers message
Sep 27, 2007 | AT&T 1738 Digital Answering Machine
RCA DRC8030N Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
