Question about Hamilton Beach BrewStation Deluxe 47474 12-Cup Coffee Maker
My Brewstation Deluxe coffee tank is plugged. Cleaning won't fix it. I suspect that I need to remove the filter inside, but that seems impossible as there are 4 plastic tabs keeping it in place. Last time this happened I had to have the whole tank replaced. Now that it is off warranty, I can't afford that. Any ideas?
SOURCE: BrewStation
Are you pouring the water into the water reservoir? My wife bought a BrewStation and the same thing happend to me the first time I used it. Of course, I did not have the directions. I filled the removable water/coffee tank, but did not transfer the water into the 'water' reservoir. The water does not drain by itself.
Works fine now.
Posted on Oct 20, 2007
SOURCE: Leaking Coffeepot
it is the rubber seal it just pulls off push new one on
Posted on Jun 14, 2009
  • 14 Answers
SOURCE: Brewstation Leaks
Mine did the same thing, except I have the model #47665 because the model you have I had to replace twice. It would start/stop numerous times during brewing. Anyway, if yours leaks coffee the same as mine it's because the tiny plastic part holding the small rubber gasket that controls leaking (inside the tank under the screen) is most likely broken. Apparently it's a common problem. I called HB at 1-800-851-8900 and talked to customer support. They are sending me a whole new tank (cannot just fix the gasket) for the whopping price of $5.00 to cover shipping. That's right, $5.00 for shipping gets you a whole new tank. I love Hamilton Beach. They truly do stand behind their products. Again Hamilton Beach product support, 1-800-851-8900 good luck to ya........Katherine
Posted on Jul 13, 2009
SOURCE: hamilton beach brewstation deluxe 47474
I just got mine via auction. All it did was steam, very little dripping. I took mine apart (used anyway) and found the water line has a soft tubing connecting metal pipe to plastic top drip part. It was crimpped. Was able to twist and straighten. Now works fine. Beware though when closing machine I caught a wire, had to fix that.
Posted on Aug 09, 2010
  • 23 Answers
SOURCE: Is there a replacement part for the (HB
Desiree, I just had a problem with my 3 yr old Brewstation 47665. There is a limited warranty (1 yr) for the model. Call Customer Service and I am sure they can help you. You can find the number on their website. In my case, I would have to buy a new tank for $14.00 plus state tax. $14 is a lot better than $60. The coffee was dispensing extremely slowly and there is no way to remove the parts to clean. I didn't want to part with this coffeemaker, I LOVE IT!
Posted on Sep 02, 2010
Hamilton beach brewstation leaking
Sorry but if this company is like the BUNN corp there are not parts available to repair. they want to sell new only.
Nov 17, 2015 | Hamilton Beach BrewStation Deluxe 47474...
The coffee just dribbles out of the canister when bar is pressed instead of pouring out like before.
The plumbing is clogged and needs cleaning. Follow the instructions of the unit for thorough cleaning. Think it involves the use of a vinegar solution that you pipe thru the system.
Sep 09, 2015 | Hamilton Beach Brewstation Brew Station...
Is there a replacement part for the (HB Brewstation model 47665) tank? It's barely a year old, and the tank has a tiny crack (at one of the screws at the hot plate) and leftover coffee spills all over the...
Jul 02, 2010 | Hamilton Beach BrewStation 47665
Brew station is extremely slow, suspect it needs cleaning.
You can run a cup of vinegar through the machine. Run it just as you would making coffee, except without the coffee. Run water through the cycle at least twice to remove sediment and the vinegar. Works like a charm.
Jun 16, 2010 | Hamilton Beach BrewStation Deluxe 47474...
BrewStation® 12 Cup Coffeemaker With Timer * LEAKS
Contact customer service and have them send you a new gasket for the coffee tank. Doesn't cost much and adds a couple years or more to the life of your coffee maker.
Jul 29, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Leaking Coffeepot
Jun 01, 2009 | Hamilton Beach BrewStation 47214 Coffee...
My hamilton beach brewstation is leaking.
There is a spring between the lever and the o-ring. It may have popped out when you cleaned the pot. That has happened to me before. The spring is necessary to hold the seal down until the lever is pushed.
Mar 13, 2009 | Hamilton Beach BrewStation 47214 Coffee...
BrewStation
Works fine now.
Oct 12, 2007 | Hamilton Beach BrewStation 47214 Coffee...
Hamilton beach brewstation deluxe 47474
Yup I have the same problem as well. Tried the cleaners too. Currently getting the run around from customer service. If they get me a solution Ill post it.
Nov 15, 2006 | Hamilton Beach BrewStation Deluxe 47474...
Hamilton Beach BrewStation Deluxe 47474 12-Cup Coffee Maker Logo
55 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
