Question about Maytag Neptune MAH5500B Front Load Washer
The washer stopped draining during run. It was washing a rug with a back that was coming apart. I think that the bits have clogged the input to the drain pump. First question. Can I get to guts from the front. If so, how do I remove the front panel? thanks
  • mikerobintod Sep 03, 2010
    Found the service manual online. You get to the pump through the back access panel (as implied by the note above). Once unhooked to the input and output hoses and the wire harness, you just twist the pump to release it from the bottom plate of the machine.
    It turned out that the hose from the sump to the pump intake was just full of the rubber carpet backing. My wife swears that she will never try to wash same again. You gotta love em. The only real casualty was that one of the three veins on the pump impeller got broken off. Looks like about $55 for a new pump -- not too bad. I put the old pump back in. It seems to work okay, albeit less enthusiastically. Perhaps it will hold until the new pump comes in.
    I executed the Service test in the manual, and it passed. I don't know much about these machines. I am strictly a DIY when I think I may be able to handle the problem (save some cash). But to my untrained eye, this Maytag Neptune sure seems quality built.
    Thanks for the suggestions. Mike
    President:
  • 2,702 Answers
No you cant just tip the washer over and get to the pump from there
Posted on Aug 07, 2010
Testimonial: "Sounds like a good suggestion. I have to leave this project for a couple of weeks, but will try your suggestion when I return to it. thanks, Mike"
Washer did not drain as usual during the spin cycle
Posted on Sep 03, 2010
Frigidaire front load washer. water is not draining out during spin cycle leaving the clothes clean but sopping wet.
It sounds like either your drain hose is clogged or the water pump is inop. If you have washed any rugs or material the may come off and clog the pump that could be the problem.
You can remove the lower front cover ( 2 screws I think) and follow the black rubber hose to where the pump is located on the lower right side when facing the washer. The hose has a spring clamp you can remove if necessary to clean the hose.
Remember to unplug the washer when working on it.
Aug 09, 2010 | Frigidaire ATF6000ES Front Load Washer
During the wash cycle, the washer started beeping and I found a code "LD" on the dial. What is the problem
Here is what the manufacture says about LD -- my comments will follow
Long Drain
Ld flashes when the water level does not
change after the drain pump is on.
ô Is the drain hose or the drain pump clogged?
ô Is the drain hose height greater than 96"?
ô Is the pressure hose connection from the tub
to the machine/motor control pinched,
kinked, plugged or leaking air?
Phil's comments ---->
Almost always this code is due to a plugged drain pump or hose, it is especially common when washing a rug with a rubber backing that comes off or small articles like baby socks that get caught in the drain system of the machine. Depending on how adventurous you feel in taking this unit apart is your call, but due to the complexity of it I would recommend calling a service expert.
Just one guys opinion..
Apr 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washed a bathroom rug, which fell apart in the
The little pieces off of the bottom of the rug are clogging up the pump. Clean out pump.
Jan 15, 2010 | Dryers
I clogged my washer drain...
follow the discharge hose into the washer body --- the trap will be at the housing the hose connects to --- not a big job. be sure to unplug the machine and hand bail the standing water out of the basket. keep a sponge and rags with a pail for the water in the trap and hose. no special tools, but it will be metric
Jun 20, 2009 | Maytag MAH8700A Front Load Washer
WASHED RUG IN MY NEPTUNE WASHER. rUG CAME APART. washer won't drain all the way. ND COMES UP.RUG WAS SHAG TYPE.hELP!
You will have to clean up drain system in washer. Get the rug pars out. A wet vac is a useful tool here.
May 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front Loader Frigidaire will not drain model no. LTF530FSO
check to make sure all hoses are not clogged - our washer hose before the pump was clogged due to washing a rug that had deteriorating rubber backing - would not drain until I flushed out the hose that goes from the tub t the pump.
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Clogged pump on Affinity Washer
Exactly the same problem. Washed a small area rug that appeared to have pretty much disintegrated. Machine would not drain. Got the same e 20 code. Checked the drain hose, and it was fine. Reamed the house drain just to be sure. Drum appears to have drained, but now the motor runs, and no water enters the machine. Both water hoses are flowing. No further error codes. Nada.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Kenmore Front loader clogged up
open the back panel to access the hoses. look for the largest-diameter round hose and disconnect it. this should be the drain hose. it also should lead to a vertical-rising pipe or hose that then dumps downward (U-tube at top) into your house piping outside the washer. My hunch is the clog is somewhere before the area where you disconnected and may need to remove all hoses from the pump and also clean pump's impeller.
May 30, 2007 | Kenmore 46462 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
174 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
