The water in my washer does not shut off after it fill causing it to overfill the only way to stop the water is turn it off at outlet
  • 343 Answers
No brand or model shown.
The most likely cause of your problem is a faulty inlet valve. If the off posn on the machine stopped the flow, the inlet is ok. As you have to turn off at tap/faucet, it means the inlet valve is faulty. Replace the faulty inlet valve and all should be well!
Good luck.....Nomess
Posted on Aug 08, 2010
Testimonial: "thats what i did thank you"
PE error code for my lg washing machine
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Mar 15, 2015 | LG Washing Machines
PE error on WF 1330TP turbo drum machine
Aug 14, 2014 | LG Washing Machines
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
I turn on the top load washer ,it starts to fill
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 13, 2009 | Kenmore Washing Machines
Does not stop filling with water
A machine that overfills or underfills can often have a faulty water level switch. It's a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level, it activates the switch to shut off the water. Make sure there is no damage to or obstruction in the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad switch. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 01, 2009 | Washing Machines
Flashing FL
Hi
If you have error code FL it means flood condition i.e. FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
If its LF which means long fill i.e. when the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore series 80 washing machine overfills, it will not start washing, it just fills and runs over
Hi, The first part to check is the inlet valve. If you shut the washer off, will the water stop? If the water continues when the power is off to the washer, change the inlet/mixer valve.
If the water stops filling when the power to thee washer is shut off, the water level switch needs checked.
Please let em know if either of these help so I can assist you further.
Vic
Jun 20, 2009 | Washing Machines
My Maytag Washer keeps running water and won't stop.
regardless of machine being on or not???sounds like a faulty water inlet valve youll need to replace the valve..
If the water level just overfills and floods over the top of washer but turns off when the unit is shut off, then it sounds like a bad fill switch.
May 10, 2008 | Washing Machines
Whirlpool washer LSQ9264HQ
Either you have a faulty water valve, which would either need to be fixed or cleaned, or you have constant power to the valve caused by a problem in the controller which does not allow the cycle to advance. If, as you say, it does not overfill, then apparently your water level control pressure switch is operating and causing the pump to turn on and drain as fast as it fills.
Feb 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Elite Calypso
FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. This could just be a fluke, or you could have a possible bad pressure switch that is not shutting off the water supply correctly. In addition, fill valves have been known to short out causing water to constantly fill in the wash tub. Lastly, your household water pressure could be too low and won't shut the fill valves off properly. Inlet water pressure should be a minimum of 10-20 psi. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display. I hope some of this leads you in the right direction.
May 12, 2007 | Kenmore Elite 21086
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
