Question about Acer Aspire One PC Notebook
Does the aspire 5532 come with a bluetooth adapter to connect phone to computer?
  • 31 Answers
No it does not come with the Bluetooth…
You have to buy one
Regards
Salim
Posted on Aug 08, 2010
ACER ASPIRE 5532 RECALL
This is more than likely. Your local computer repair shop will be able to advise.
Feb 12, 2015 | Acer Aspire 5241 5251 5332 5334 5338 5516...
My acer aspire 5532 just went black. The power button goes on' but no response whatsoever. Any clues?
Just try this steps
1) Shut down your computer and disconnect the battery and also the Ac adapter which is connected to your laptop, and then once your computer is Off just press and hold power button for at least 15-20 sec and yes do not lift your finger from the power button
2) Reconnect everything Battery as well as your Ac adapter, and try to see if the issue is resolved or not
3) Load BIOS setup Default
4) Try to go to safe mode
5) Do system restore when your computer was working fine
I hope this will answer and fix your issue
Regards
MAJID KHAN
Nov 30, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Acer 5532 Touch Pad Not Working
Here are a couple of ideas from a Google Search:
Press the key to the left of the On/Off button. The key has a picture of a finger pressing the touchpad. So simple, so elegant, so little information out there about it.
https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/my-touchpad-on-my-acer-aspire-5532-laptop-isnt/51f5de30-b465-e011-8dfc-68b599b31bf5?auth=1
Dec 23, 2017 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Do I have bluetooth in order to connect with my mobile phone on this Acer 5532
It appears that this model Acer does not support Blurtooth devices.
You can check the specifications for this model laptop on this WEB site.
http://support.acer.com/acerpanam/notebook/2009/acer/aspire/Aspire5532/Aspire5532sp2.shtml
Jul 01, 2011 | Acer Aspire One PC Notebook
How can I on the bluetooth on my laptop aspire 4743Z?
Connecting your Bluetooth wireless phone with your laptop is called pairing, and I'll use a Blackberry Curve to show you how it works. I'm assuming your laptop comes with a built-in Bluetooth adapter (or you can also get a Bluetooth adapter that plugs into one of your USB ports).
First make sure that Bluetooth is enabled on your phone. For Blackberry phones, that means selecting the "Set Up Bluetooth" application from the main screen, and then selecting "Enable Bluetooth" after clicking the menu button.
Next, set up your computer to allow Bluetooth connections. If your computer comes with Bluetooth, then you'll see a Bluetooth icon in your Control Panel (Start button -> Control Panel from Vista):
control-panel-bluetooth.jpg Double-click the Bluetooth icon and you'll see a Bluetooth Devices dialog. Click the Options tab and make sure the options to "Allow Bluetooth devices to find this computer" and "Allow Bluetooth devices to connect to this computer" are both checked
bluetooth-devices-options.jpg Next, click the Devices tab and then click the "Add" button. This will open the Add Bluetooth Device Wizard, and after verifying that your device is set up and ready to be found (ie. Bluetooth has been enabled on your wireless phone) it will try to find your phone.
add-bluetooth-device.jpg Select the Bluetooth device and click Next to set up a passkey, which is a number that associates your computer with a Bluetooth enabled device. For security reasons, most Bluetooth enabled devices (with some exceptions, such as mice) require you to use a passkey. Using a passkey helps ensure that your computer is connecting to the device that you intended and not someone else's device that is nearby.
You can choose your own passkey or let Windows choose one for you. Click Next and then pick up your phone, which will prompt you to enter in the passkey. After entering the passkey in your phone, Windows will finish the pairing process and your phone will be connected via Bluetooth.
May 10, 2011 | Acer Aspire 5742Z-4200 Notebook
How do i turn my blutooth on, on my Acer Aspire 5332?
Install the provided Bluetooth wireless adapter. Purchase and install a commercially available USB-to-Bluetooth wireless adapter. Enable your computer's built-in Bluetooth wireless support. This should then be able to connect to anything that has Bluetooth support.
Hope this helped. Good Luck!
Jan 03, 2010 | Acer Aspire 5610-4648 Notebook
Aspire 3000 laptop
Normally you setup a passkey or use 0000 or 9999 as a passkey.
The question is, does that pop up when you try to connect a USB device? Do you get that when you try to install the dongle? (That shouldn't happen). If you are trying to connect a PDA or cell phone, you setup the passkey for the connecting device on the computer then type it in to the PDA or mobile phone. If you are trying to connect a bluetooth headset, then you use whatever code is from the manufactorer. Normally this is 0000 or 9999.
Hope this helps!
Oct 18, 2008 | Adapters.com Bluetooth USB Adapater, USB...
Bluetooth prolem on acer aspire 5720
welcome to FIXYA
Set up a Bluetooth enabled deviceTo set up a Bluetooth enabled device, you need to do three things:
  1. Add a Bluetooth adapter to your computer.
    This is usually done by plugging the adapter into a USB port. (If a Bluetooth adapter is already built in or attached to your computer, ignore this step.)
  2. Set up the device so that your computer can find it.
    To do this, you must:
    • Turn the device on.
    • Make it discoverable.
    To learn how to make a device discoverable, check the information that came with your device or go to the manufacturer’s website.
  3. Install the device.
    To install most devices, such as a mobile phone, keyboard, mouse, or personal digital assistant (PDA), you can use Bluetooth Devices in Control Panel. If you have Bluetooth wireless technology installed on your computer, follow these steps:
    To install a Bluetooth enabled device
    1. Click the Start button getcontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=signed1, click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
    Click Add, and then follow the instructions.
i hope this helps you out have a good day :)
Jul 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire One  PC Notebook Logo
922 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
