Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Need to know way my 1991 25 hp evinrude motor only ideals. At full throtle acts like it wants to shot off but don't. can someone tell me what the problem might be? thank-you!
  • 135 Answers
SOUNDS LIKE THE HIGH SPEED JET IS CLOGGED = REMOVE CARB DISSASSEMBLE AND CLEAN USE SEA FOAM IN FUEL
Posted on Aug 10, 2010
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
How to get better millage on activa 2011 model
In this article: Specifications of New Honda Activa says that the millage is about 52kmpl, but this data is without full throtle, stable velocity, no braking, under ideal conditions. Don't worry if you get millage between 40-47kmpl with normal conditions.
If you want to improve it, don´t do big brakes, work with the throtle slow, and try to keep the velocity in a reasonable range.
Dec 11, 2014 | 2011 Honda Activa
Husqvarna 45 carb jet blocked
Could be a fuel starvarion problem. Theres one thing you could try before you try stripping and cleaning the carb. Back off both tuning screws, and pull over till it fires. Then screw both back in and reset them to standard. H3/4 of a turn anticlockwise, L1 full turn anticlockwise. Then try firing it up again. Sometimes its enough to cklear any dirt in the carb. Failing that, Its a strip and clean.
http://www.ebay.co.uk/itm/Evinrude-Johnson-Mercury-Yamaha-Outboard-Motor-CARBURETOR-CARB-CLEANING-TOOL-/261167700551?pt=Boat_Parts_Accessories_Gear&hash=item3cceceda47
These carb cleaning tools are great, but you have to know where and where not to be putting them. Certain parts of Zama carbs and Walbro carbs have tiny valves within the carb. So be carefull.
Apr 15, 2013 | Husqvarna Garden
70 hp johnson seahorse ceased
Hey I recommend checking out the boating forums. Someone over there can tell you whats best. You may even be able to find an answer on there with the search.
http://forums.iboats.com/johnson-evinrude-outboards-24/
Mar 09, 2013 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
Have Evinrude 200 hp 2 stroke on starcraft 20ft STX 2050. What is the optimim prop for this boat. Currently rpm 4450 at 40 mph. Seems slow.
wide open should be a max of 5500 rpm that boat and motor should have a 1450 x19p prop on it but wide open throtle should run 4500/5500
Jun 18, 2010 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
301 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
