Question about Dishwashers
Dishwasher Flashing Light
My model is pretty old: Kenmore 66517779990.
My dishwasher will not respond to any input and continuously flashes the lock-on button. I have read that the problem could be either the electronic control board (p/n: 9744031), or the console control assembly (touchpad; p/n: 3383469). However, it is not clear to me how to determine which one is the problem.
Diagnostics I have attempted: I have disconnected and removed both controls (listed above) from the dishwasher and reconnected them (while the breaker to the dishwasher was off), giving time for the circuits to discharge. The Cancel/Drain popped on, ran the draining mechanism, and then another light popped on and started to flash--still no response to input.
Although I can buy a new console control assembly, since my model is so old, the electronic control cannot because it has been discontinued. If the electronic control is what I need to replace, can it be bought somewhere else other than Sears?
Any help would be appreciated.
Thanks,
Bernard
  • bjfcom Apr 27, 2008
    Ahh, I have to ammend this. I missed one connection between the panel and circuit board. This reset the dishwasher. It works now, however, clearly something is wrong, or else the problem would have never of cropped up. What should I do to stop this from happening again?
2 Suggested Answers
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore Dishwashers
Whirlpool quiet partner iii pots & PANS LIGHT flashing
test the steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 22, 2013 | Dishwashers
Reset for dishwasher
What model Kenmore dishwasher?
Jul 10, 2013 | Kenmore Dishwashers
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Why won't my Kenmore dishwasher display work properly?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
Dishwashers Logo
173 people viewed this question
Top Dishwashers Experts
