Question about Garden
Snapper riding lawn mower loosses the power to move up hill from a dead stop even though the motor has plenty of power, how can i fix this? is their a belt that is slipping?
  • 51 Answers
If it is belt driven yes it sounds like its slipping may be worn or some idler pullys are adjustable via a slot in bracket where bolt goes through pully if it is disc driven the rubber disc is probably worn. if mower is a rear engine rider close vent on gas cap,set brake then lift mower from front and stand up on rear bars at bottom by floor you will see a rubber disc which is held on by 4 nuts. if has electric start try not to leave up for too long,should only take 15 min to replace hope this helps
Posted on Aug 08, 2010
  • tom Sep 03, 2011
    will tgear?his cause it not to go into 4th and 5th
My Snapper NXT2346 just stopped while mowing checked battery is ok, no power to starter or safety switch, changed fuse, seat switch check seemed to be ok - any suggestions?
Those tractors have a few safety switches and they all have to be engaged in a closed position for you to have ignition and have unit operate. Did you check the obvious ? - ignition switch?
If it just stopped dead while you were mowing then the ignition had to have been interrupted. That switch powers both the starter and ignition circuits.
Sep 11, 2016 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
Brake system
Michael, Check the attached links, 1st link is snapper where you can get info from support,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tractor Riding Lawn Mower Products Snapper Mowers Tractors
Snapper Lawn Mower Transmission Brake Clutch Parts
Snapper Brakes
Snapper Lawn Mower Parts Lawnmower Parts Discount Online Parts
Apr 09, 2016 | Snapper Garden
My Craftsman riding lawn mower LT2000 (2002/2003) stopped moving. The drive belt seems to be loose. The engine starts and cutting blade engages fine. Was working fine but stopped working when it started...
there should be a drive belt tensioner somewhere on the belt, it usually works off the clutch/brake, when you push on the brake it apply's the brake and also takes the tension off the belt to stop it from moving.
Not sure of your ride on mower but that is how my ride on mower works so I hope this helps.
May 19, 2014 | Craftsman Garden
Snapper mower
motor siezed up remove plug pour oil in cylider work it back and forth till it come loose and turns freely should start up
Aug 09, 2013 | Garden
When first start my husqvarna yth 150 runs fine goes up hills plenty of power after running for while starts loosing power wont go up hills will stll move on flat surface
Hi, it sounds like the hydrostatic drive is getting too hot. Remove the battery and battery cradle and clean all grass and debris from around the hydrostatic drive and cooling fins. Also check the fan wheel on the hydro is not damaged. Regards Phil.
Apr 28, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have an older Snapper lawn mower that just stopped moving while I was mowing grass. I have put a new drive plate on it (the one that has the rubber around), but that didn't help it. When I stand the...
your trans axel has striped out in side you will need to get that in to the shop let me know if this helps you or if you need to find a shop
Oct 04, 2009 | Garden
Garden Logo
633 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
