Question about GE 17.9 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White
Freezer works even makes ice, bottom 60 degrees
    Problem Solver:
  • 14 Answers
Sounds like evaporator is iced up due to problem with the defrost system preventing proper air flow
Posted on Aug 08, 2010
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
I have an amana bottom freezer/refrigerator model ABB2522FEQ. the bottom freezer works great, but the coils have frozen two times. I thawed coils out again and it only lasted 2 weeks, eventhough the fan...
HI,IF THE FREEZER IS BUILDING ICE ON EVAP COVER THAT IS NOT DEFROSTING PROPERLY,REPLACED THE CONTROL BOARD AND DEFROST B-METAL TO REPAIRD THE PROBLEM..
Jul 04, 2011 | Amana ABB2524DE Bottom Freezer...
Refridgerator is warm, freezer is freezing
Defrost problem. Most likely the defrost heater or defrost thermostat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 02, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
In the back of the freezer there is a ''condenser'' unit that leaks & ice forms along the back of the freezer and bottom. I have opened a drain hole & attached a hose but the water freezes before...
Good day,
First, if ice maker equipped, the fill tube going into the ice maker may be leaking. Shut the water off to the machine, and disconnect the line for now. It can be addressed later.
Although a pain, I would recommend the machine be un plugged for 24 hours and melt and dry out the freezer compartment. If you have a floor fan to blow into the freezer compartment, even better.
Second, There is a limit thermostat clipped to the top of the evaporator. It's a round 1" device.
If I have a problem machine with this problem, I bump the temperature of that tstat 5 degrees.
For example, if it's a 50 degree tstat, I replace it with a 55 degree.
If 55 degree I replace it with a 60 degree. If 60 already, I replace it with a new limit of the same value, since there is nothing above 60 degrees that makes sense. This is to guarantee the old one isn't opening prematurely and not producing enough heat.
As an option, and you might want to wait on this, there are timers that have a longer defrost cycle to aid drainage.
Timers have a defrost cycle that runs between 20 minutes to as high as 35 minutes. Longer is better.
In this case an appliance parts house is your friend.
With the complete model number, ask the counter what cycle your timer has. If your in the 20 minute range, I suggest you go to 30 or 35 minutes. A sharp counter man should be able to find a substitute. GE timers run commonly in the upper range.
I know it sounds like we're trying to kill a flea with a sledge hammer, But in an attempt to make the machine more energy efficient, over the years, they have cut back on defrost time, defrost heater temperature, and heater wattage.
P.S. The timer is mounted in the housing on the top in the fresh food compartment.
Dec 04, 2009 | Refrigerators
Freezer on bottom. freezer working but fridge at 60 degrees.
make sure the evaporator fan is operating and the air-flow diverter is also open on the unit
Oct 30, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How do you manually start timer on fisher paykel
We disconnected the refrigerator and took the back of the freezer apart. There we noticed ice had built up on the coils. After removing all the food, we let the freezer defrost for 3.5 hours. Then we connected it, and it started to cool down immediately. After 1 1/2 to 2 hours, the refrigerator was down below 40 degrees. All food was replaced, and now the refrigerator is working properly All of this was down to the Fisher Paykel Model E522BRM.
Aug 31, 2009 | Fisher and Paykel Active Smart E522B...
We have an Admiral top freezer refrigerator. Freezer is working refrigerator is running at 60 degrees.
If there is no ice on the back wall of the freezer, make sure the freezer fan motor is running. If there is ice on the back wall of the freezer repair the defrost components. Timer,heater,thermostat.
Jun 09, 2009 | Maytag Admiral Top-Freezer Refrigerator
Refrigerator/freezer not cooling evenly top to bottom
good then go ahead and ohm out the sensor and the relays to see if the resistance is close to the normat. 70 degrees is roughly 1000 ohms. relay you are lookling for continuity or open. then you can also ohm the fan motor too. let me know what you find;.that will determin whts bad and whats good
Dec 25, 2008 | Kenmore Refrigerators
Fridge fine, freezer not freezing
Weird scenario... the first thing I would do it to remove the interior back panel of the lower freezer section after the unit has been running for hours and check the coils to see the frost pattern on them. Should be even white frost all over the coils with no solid frozen coil (block-O-ice thing). Check the fan is running above the coils, etc. when. If everything is OK then you may have a control board problem. Let us know what you find in the freezer coil investigation and we can go from there.
Jan 15, 2007 | Samsung RB2155SH Bottom Freezer...
GE 17.9 Cu. Ft. Frost-Free Top-Mount Refrigerator - White-on-White Logo
70 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
