Question about Fellowes DM15C Shredder
Shredder runs on after shredding. Cannot find the sensors to clean.
  • Frank Turkovich Aug 07, 2010
    The lever is not stuck down. Is this the only sensor? If so how do I loosen it up?
  • 1,675 Answers
Hi the sensor is in the top..if you look in the gap where you put the paper, you should see a leaver in the middle somewhere, this is the turn on switch for the cutters, it may be stuck down...hope this helps
Posted on Aug 07, 2010
  • steve morris
    steve morris Aug 07, 2010
    remove the top, and turn it over then push it back, you cannot take it apart, it is connected to a micro switch, just push it back and forth, spray a bit of wd40 on it or some light oil..it could be just clogged up a bit
    President:
  • 2,030 Answers
Its a small tab inside the paper slot
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 08, 2010
My Staples 16 sheet Microcut shredder starts the shredding operation after I push the button and continues the shredding operation after I shred a paper. How can I get the shredding mechanism to stop...
It's a tedious process to clean it out. Most auto switch shredders use either a tiny little lever or an optical sensor in the paper feed slot. Usually removing the shred head, picking all the paper out and blasting all the dust out with air will clean it up. Then run a few sheets of paper with shredder lubricant (basically clean mineral oil) to oil the blades and it should be good to go again. Just be careful cleaning that cutting head. I've donated many drops of blood to office equipment over the years.
Mar 14, 2015 | Staples Office Equipment & Supplies
My shredder runs non stop, when I insert paper to shred , it stops... I push reverse, it works , pull paper out and runs non stop.......
Sounds like a bad or stuck sensor, acting as if it is always seeing a peice of paper in it. Check if you can find it and maybe it is just stuck to the on position..
Nov 07, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
My Fellowes shredder DM17Cs won't stop running unless shut off
Blow some canned air down into the feed slot to clean the sensors.
Nov 20, 2009 | Fellowes Powershred DM8C (Confetti)...
Shredder continues to run after page is shredded, must be manually switched off.
there is a sensor that detects paper in front of it to turn on the shredder mech. it is probably covered with paper dust so the machine constantly thinks there is paper being shredded. give it a clean with a qtip moistened with isopropyl alcohol - make sure the shredder is unplugged first.
Jun 20, 2009 | Fellowes Powershred P-45C Shredder
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Apr 29, 2009 | Fellowes Powershred 220 Shredder
Shredder won't shred
They may be a compression switch on the lip where it sets on the bucket. This it to prevent it from running while its off its buckette. If this is not all the way in it wont run. Look for that clean any safty switch or buttons you find.
Slap it with your tax booklet and call me in the morning. Good luck DFD
Apr 14, 2009 | OfficeMax 0M96431 Shredder
Shreds halfway, then stops. Fellowes SB-95C
on the underside of the shredder, at the top of the space where the cuttings box is, there are 2 sensors, 1 at either end of the shredder blades. it sounds like these sensors could be either dirty, or defective. try to clean these with a cotton bud or similar. it may need new sensors, bu it is worth a try!
Jan 30, 2009 | Fellowes SB95C Cross-Cut Shredder
Shredder won't shred - all paper is cleared - works intermitantly
Run the shredder in "Reverse" mode for 15 seconds.
Oil the cutting head thoroughly as this is a High Security shredder.
Test it at 4-5 sheets.
They always overrate the capacity but if you want to keep it operating, shred 3-5 sheets max.
Running for serveral minutes could be due to dirty optic sensors. Unplug the shredder, remove the top (2 screw underneath front and 2 in back). Remove the sensors (they have a little pushbutton tab) and clean thoroughly with a soft cloth. Re-insert the sensors ensuring they lock in place, reset the top cover and test.
Jun 05, 2008 | Geha Primo 3900 HS Shredder
Fellowes DM15C Shredder Logo
44 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
