Question about Dishwashers
The door on my indesit DI450 will not close. I can't see what is wrong with it.
Indesit model iwe7125b problem f06 what does it means?
F06 : DOOR LOCK fails to close/open, door lock triac open/closed, frequency signal fault.
Action: Switch off the device. Disconnect power. Wait about 3 minutes. Open the door, then close, reconnect device to the network. Start device
Dado
Dec 20, 2014 | Indesit Washing Machines
Whats remedy of di450 error code 1300
Print head (Which is unit that has the LASER in it) motor is bad. Did you try resetting the machine by opening closing the front door?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 29, 2014 | Minolta Office Equipment & Supplies
In my machine when we switch on the machine the code c- 0920 appear
One of the trays has a lift problem, try clearing by touching the small wrench in the bottom left of the display (if the wrench isnt there open and close the front door) after touching wrench open and close front door, if that doesnt work one of the trays needs troubleshooting
May 01, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
C13fc code di450
image processing board and or print head (Where the LASER is located) or combo. SO check all connection between the image processing board and the LASER (Print head) open and close front door to clear
Jan 25, 2014 | Minolta Office Equipment & Supplies
Di450 Minolta Code C0000
fusing (The Hot part) motor has failed to turn jammed broken gear(s) bad motor or worse the main board burn out. open close front door to reset
Jan 22, 2014 | Minolta DiALTA Di183 Copier
DI450 C11A4
Memory board failure!!! Would check the memory sticks on the control board re-seat then clean there contacts if have to replace them Open /close front door resets
Jul 31, 2013 | Minolta Office Equipment & Supplies
Replacing a DoOr Seal
as i remember it, you will have to take off the door front panel and slot in the seal from inside of the lower door. if im thinking of the wrong model and the advise is wrong i will get back to ya.
Mar 16, 2009 | Indesit 24 in. D63 Free-standing...
Dishwasher DI450 Door
Hi chrissy99
Not sure what do you mean by keeping the door to stay open. Well if you want to keep the door open during operation , identify the mechanism that triggers the on button .
In my dishwasher to check if it function properly , I keep a small wedge / strip near the handle / button which opens the door.
Dec 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
