Acer computer want boot says media test faliure check cable
  • commodoreb Apr 27, 2008
  • 103 Answers
Sounds like your boot order is set wrong or your computer is not seeing your hard drive.
When you boot your computer you must go into your System Setup (Usually by hitting Delete, F2, or F12 while the Acer logo is on the screen). Look for a menu called boot order and make sure that your hard drive is the first one in line.
Posted on Apr 27, 2008
  • Richard Wilbur Apr 28, 2008
    Yes you can. Your hard drive can be replaced rather easily. You can order one straight from the manufacturer to make sure it is the proper type. Usually it unscrews from the bottom, and slides out the side. I am not farmiliar with your model, but even an Acer salesman should be able to tell you how to replace it. Good luck!
Acer aspire d257 pxe-e61: media test failure, check cable error
Your computer tries to "boot" (start-up) from several devices:
* floppy-disk (if installed)
* disk-drive (if not "dead"),
* CD/DVD optical device (if "bootable" media has been loaded)
* PXE --> Pre-Execution Environment -- checks if there is a connection between the network-adapter on your computer to a "boot-server" on your local network -- it can load Windows from that "boot-server".
The "media-test failure" indicates that there is no network-cable attached to your computer *AND* the other-end of the network-cable is *NOT* connected to the "boot-server". So, you can that "error" message.
Is your disk-drive "dead" ????
Jan 24, 2013 | Compaq Presario-Notebook 700 Series, 2500...
PXE-E61: Media Test Failure
My computer gets this message when I try to boot it:
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Intel PXE ROM.
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Shouldn't be enabled by default
on Jan 04, 2009 | Acer Aspire 3680 Laptop
I have a fiujitsu hard drive in my acer aspire 5315 my keyboard has no keys just some rubber tips and when i turn on its says broadcom UNDI PXE-2.1 v10. 0. 9 copyright yada yada and then it says: PXE-E61:...
The keyboard needs replacing. Replacement keyboard for your laptop maybe available from this WEB site.
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Dec 18, 2012 | Computers & Internet
Pxe-e61: media test failure, check cable acer extensa 542
Your computer tries to "boot" from several devices:
* floppy disk
* disk-drive
* external CD/DVD
* USB memory stick
* PXE ("Pre eXecution Environment)
To use PXE, you need "media" -- a network cable connecting yur computer to a "boot-server". The "media test faiure, check cable" reports that no network-cable exists, or that it does exist WITHOUT being connected to a boot-server.
Probably, your computer failed to boot from a DEAD disk-drive, and then tried floppy/CD/USB before checking PXE.
Replace the disk-drive.
Jul 30, 2012 | Compaq Presario-Notebook 700 Series, 2500...
Upon start up my Dell Mini keeps showing a code stating " intel UNDI. PXE.2.1 ( BUILD082) For Realtek RTL8101E/8102E PCI Ethernet controller v1.08(080408) PXE-E61: Media test faliure. check...
You computer is trying to boot from the LAN port (Ethernet).
Go into the BIOS by pressing either the F2 or the Del key. Check and make sure the hard drive is recognised by the system as with it saying "Operating system not found" does not sound good and could mean a hardware failure.
If it is seen by the BIOS check the boot order, change it to the HDD as the first boot device.
Dec 15, 2010 | Dell Inspiron Mini 10 Notebook
Acer Aspire X3200 - VIRUS - Won't boot or re-install
it seems like the HDD is not getting recognised , try this might help you get into BIOS setup by tapping delete key or f2 when system turns on , load the defaults settings for bios then try loading OS , if you are getting the same error message that means hdd has gone bad or the cable to the hdd is loose
Jun 29, 2010 | Acer Aspire X3200 PC Desktop
When I turn my laptop on a black screen appears with: PXE-E61: Media test faliure, check cable PXE-M0F: Exiting Broadcom PXE ROM. No bootable device -- insert boot disk and press any key I do this and...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. Please click on this link and follow my instructions :-
May 29, 2010 | Acer Aspire 5720-6661 Notebook PC
Acer 4520 laptop media test failure
Your hardirve is damaged or your partition is corupted to fix this problem reinstall windows and make a new paetition or check inside your computer to see if a cable from the hardrive is desconnected.
Jan 17, 2009 | Acer Aspire 5610-4648 Notebook
sounds like hard disk faliure, suggest getting a new hard disk or perhaps attempt a system reinstall. Its not the fan but the hard disk.
Aug 28, 2008 | Tablets & eReaders
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
