Question about LG 42PC3D 42 in. Plasma Television
My LG CRT HDTV will not turn on. it just clicks on and off but no picture appears. Was working fine, I had my laptop connected to it streaming video from the net and when I had finished and returned to the normal channels from AV3 this happened.
  • LG Master
  • 12,061 Answers
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, LG, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand.
http://www.retrevo.com/support/LG-42PC3D-TVs-manual/id/371bh530/t/2/
Above is your user manual below is your service and repair manual.
http://elektrotanya.com/lg_42pc3d-series.pdf/download.html
Posted on Aug 08, 2010
  • 4,889 Answers
I have seen this before. This has nothing to do with the inputs. If you see a constant blinking LED at the front when you hear the clicking noise, then you probably have a bad flyback switching regulator. It is also possible that some near by components may be shorted. A component level repair is possible and shouldn't cost you too much.
  • 2 more comments
  • alan_poole Aug 08, 2010
    Thanks, I will follow up on your suggestion.
  • eagle338
    eagle338 Aug 08, 2010
    And reject my solution?
    Not at all, just seeing if there were other ideas you never know. I intend to contact a technician tomorrow and your suggestion will be what I am telling him. No offence meant hopefully none taken.
  • eagle338
    Mope no offense. Only my rating. Anyways good luck with the repair.
After installing an outside antenna, our unit will not get streaming media.
Roku 101: everything you need to know about your Roku ...
https://blog.roku.com/.../roku-101-everything-you-need-to-kn...
Roku, Inc.Dec 22, 2011 - You will find in-depth posts on new channels, features and updates, and ... to stream your personal media from a laptop, desktop or media server. .... Alsomake sure your phone is connected to your home WiFi signal and not an outside one. .... The Sony unit seemed possible, but after watching the video I ...
Mohu Sky 60 Amplified Attic/Outdoor HDTV Antenna with ...
www.amazon.com/...Outdoor-Antenna/.../B00AVWK...
Amazon.com, Inc.Next step was to now get working on the install of the antenna, outside. ... Sat. that was outside, coax cable already run, and this Dish was not in use. ... I have MANY more pictures, it appears that Amazon will only allow up to 5? ... Three months after my initial purchase last year, the attic mounted MOHU Sky went dead. Well ...
Mohu Leaf 50 Amplified Indoor HDTV Antenna - Made in ...
Dec 21, 2015 | Televison & Video
Pixelation in full screen mode with connection of laptop to hdtv via hdmi
Try changing the laptops resolution in the Control Panel. Click Start/Control Panel and look for Display or Appearance and Personalization. Click the Settings tab and increase the screen resolution and see if that helps.
May 06, 2012 | Computers & Internet
Issues with LG 26LE5300 26 in HDTV LCD TV Both audio & video flicker off & on when connected to PC via an HDMI cable. No problem when in TV or AV (DVD) modes. PS. worked fine on Day 1, did not...
Reduce the resolution of the PC to 1024 x 768. This can be done by right clicking on the desktop ( not any icon ) click properties / click settings / slide the screen resolution pointer to 1024 by 768 / slick apply / Computer will ask if you want to save this setting /Click yes and then try connecting the TV to the HDMI port. Should work
Mar 11, 2011 | LG 26LE5300 26 in. LCD HDTV
Hdmi wont connect to hdmi on laptop - shows lg screen on laptop with no model number but shows no signal on tv
Hi andy838,
I see that you LG LCD HDTV is giving you a No Signal message on the Screen.
see steps Below on finding out what will show video on your LCD HDTV.
* First make sure that the HDMI cable is connected to your Laptop to the HDTV LG.
* On your TV check your remote control and look for the input or Source Button, this will help you set your TV for the HDMI connection.
* Once set, turn your Laptop on and see if the HDTV will provide Video from the Laptop to your HDTV using HDMI.
* I believe that works right, now we have video still we need to set the Audio to work from you Laptop using HDMI to your HDTV.
* On your Laptop lower right side look for your speaker icon, right click on the speaker icon then select Playback Devices.
* Once you've selected Playback Devices you will see a window showing you a list of devices and the first one on the list will be you HDMI connection right click on it and select set as default device this will make your audio work on your HDMI to your TV.
* Once audio to HDMI is set and you want to go back to your Laptop just set the speakers as the default device this will set your speakers have the Audio working again on the Laptop.
I hope that this will help you regarding your concern.
Have a nice day,
mvincentc
Feb 25, 2011 | LG 42LC2D 42 in. LCD HDTV
The TV typically works fine, however lately without any prompting when turned on sound is there without the picture. Turning the set on/off repeatedly used to help and eventually the picture would appear....
Make a fist bang on the tv bazel frame.See if u get a picture or flashes of a picture?If Yes,ur tv have cold solders joints on the tv video board,that the video board connected to CRT- tv picture tube.U have a soldering iron and a roll of sloders,also can u do basic soldering?Yes resolder all the Video sockets pins Holes that connected the video board to the CRT tube together.Tv shoud have picture again.
Jan 06, 2011 | Panasonic CT-36D30 TV
I have an HP dv7-1426nr model. My HDMI was working fine last night; today however it doesn't give me any picture on my HDTV. Usually when I plug my HDMI cable in it automatically transitions the picture...
a laptop DV7
connected to what, TV, no TV stated, must we beg?
on my huge 55inch LG, i click on the LG input screen , the HDMI
that is connected to the PC>
HDM1,2,3,4, etc.
then it works.
using auto connects in HDMI are not reliable, its a bad design.
you must force it. even on both ends.
I have many HDMI connected to my TV , BR-D , even have a video server on mine, and more.
so I must force them all , due to all are there running, and I must force mine every time.
HDMI can be a pain this way.
does you PC run normally,
does your PC connect to other TV ok,
does your TV connect to other HDMI devices ok>
Oct 21, 2017 | HP Pavilion dv7-1130us laptop
My 20 inch lg tv crt monitor will not show a
is video show on vcr player? if yes you need to replace jungle ic which is switching line from tv tuner to line in video.
Feb 10, 2010 | LG 42LC2D 42 in. LCD HDTV
Lost Picture
try tapping tv on side with palm and see if it works it might be a bad video chip
Oct 19, 2008 | JVC AV-32432 32" TV
LG CRT HDTV Dead no picture
if you have the b + acording the manual then you loose it
could be many things like the vert. circuit, the crt itself or
the flyback,
Aug 06, 2008 | Televison & Video
LG 42PC3D 42 in. Plasma Television Logo
71 people viewed this question
