Question about Hobart AM14C-155 Dishwasher
Do all Hobart dishwashers have a element in them for wash water and rinse water
    Scholar:
  • 44 Answers
All Hobart dishwashers will have a wash tank heating element, but the rinse water is not heated by the dishwasher, unless it has a built-in booster heater. Usually a separate booster heater is used to heat rinse water to 180-190 deg. F for hot water sanitation.
Posted on Sep 09, 2010
AM14 Display will stay in Rinse Cycle
see this probably causes:
Water-heating cycle
the heating will be importante, test the hot water, and heating elements
Timer
test the timer for contact, and probably defective.see the diagram attached.
May 07, 2012 | Hobart AM14-253 Free-standing Dishwasher
I have a Hobart AMX900-16, IT GOES THROUGH THE MOTIONS BUT THE WASH TEMPERATURE IS ONLY ABOUT 48'C. I have put a current clamp on the element cables and all proves ok. the manual that came with it does not...
Hi just wrote you a whole story and it didn't post tring to explain how to chage the temp and it didn't go through!!! I repair hobart dishwashers if you need some info call me and I will glady help!!! Make sure that you have definately checked the wash tank element you will need to take of the left side panel of the mc!! And it looks like a small orange electric blanket stuck onto to side of the wash tank!!! Dont get confused with the rinse tank elements which you access by removeing the front cover!!! This is not the correct element!!!! If you need any more help contact me and I will run you throught how to change the wash and rinse temperatures!!! Regard richard. 07918 742 442
Jan 19, 2011 | Hobart Dishwashers
My sr24h hobart undercounter dishwasher is stuck in a mode where all it does is drain water out. Will not do anything else...???
Hello There; If your unit stuck on the wash cycle and not advance to rinse cycle because the rinse water is not up to 180 degree . You've to check out the booster element and the rinse temp. I hope this will help.
Sep 19, 2010 | Hobart SR24-H Built-in Dishwasher
Not heating water up more than 80 degrees
There are 2 heating elements, one for the Rinse tank/boiler and one for the wash tank check that the rinse tank heater has not tripped out can be reset if they have one on that model.Or one of the elements may have burnt out.You will find thermostats for both behind panel under door.
Hope this helps.
May 19, 2010 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
Tank temp
check to see if your element is scaled up or your element may be damaged
Nov 21, 2008 | Hobart AM15T Dishwasher
Rinse not hot enough
145 degree is just your hot water temp and that your dishwasher hot water booster is not working assuming that this machine has worked in the past to produce final rinse water above 180 degrees. Remove the bottom panel and to the right you will see the booster tank, look for a nickel size component with a small red button on it. Try pushing on it to reset it. If that does not work, check for voltage at your heating element on your booster tank. (the thicker wires) If voltage is present then your heating elements need replacing.
Nov 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX30H washing to hot.
what temp is it washing at. washing should not be the problem. This machine is designed to rinse at 180 degrees + to sanitize dishes. The machine could be converted to a chemical sanitize, it would use bleach in the rinse water instead of 180 degree water to sanitize.
Sep 04, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart dishwasher lx 30 h
Did the clean light indicator blinking over n over? check the element wire harness connector. If disconnected fix it and run your dishwasher again.
Also you may check the continuity of your heating element.
Jul 23, 2008 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart AM14C-155 Dishwasher Logo
401 people viewed this question
Top Hobart Dishwashers Experts
Marvin
Marvin
Garth Jackson
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
