Question about Ruud Central System Air Conditioner
I have a 5 TON Ruud split unit air conditioner.The Compressor was replaced last year.Now the unit works well for about 15 minutes and then stops cooling. Thermostat says,"In Recovery". What can I do to fix the problem?
  • Ruud Master
  • 5,568 Answers
May be due to improper refrigerant pressure; I would have it checked.
'Recovery' is normally provided to allow high- and low-side pressures to return to a safe range before the unit is allowed to cycle again and yours is doing it way too soon.
Posted on Aug 07, 2010
Ruud 5 Ton UAKA Condensor fan running but compressor won't start. Internal thermal overload cycle.
Have you checked the wiring going to the compressor to make
sure it is not melted? Next, are you
able to put your hand on the top of the compressor? Check to see if it is hot or cold. You might have a bad run capacitor so let the
unit turn on, wait about 5 minutes, turn the unit off, and then tell me if the compressor
is hot or cold to the touch. Next, are
you comfortable with a meter?
Oct 17, 2013 | Ruud Matching Split Air Conditioner
Two ton spilt ac how many mfd capacitor need to be fix
usually takes 25mfd or 30mfd for compressor and 3 mfd for fan motor. Depending on what compressor is used I would recommend 30uf rating for the compressor and it should be fine, most compressor will operate within 10 to 15 percent of rating plus or minus with no problems. Also the 3mfd rating is based on OEM motor, if it has been replaced then probably a 5mfd is required.
Aug 24, 2011 | Ruud Matching Split Air Conditioner
Compresser on my 2 ton condenser unit not coming on condenser fan running but not the compresser. I already replaced the capacitor but did not fix the problem.
Check the wires going to the compressor terminals making sure there is no damage to them or to the compressor terminals..Install a hard startbobicehouse_2.jpg
Jul 03, 2011 | Ruud Matching Split Air Conditioner
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
Wiring diagram for contacts on the outside unit
I have a wiring diagram I can send you. I took a picture of mine. Mine is a Ruud Achiever PNE 2 ton.
May 23, 2010 | Ruud Matching Split Air Conditioner
Power to compressor but compressor will not start Unit is split system-2.5 ton, freon is good
i would check the capacitor( shiny little round or oval can) if bad get an exact replacement(mfd and voltage) if it is good i would try adding a boost capacitor(increases starting torque by 300%)
Jul 30, 2009 | Ruud Matching Split Air Conditioner
I had a new 2.5 ton condenser installed last year and the compressor burned out. I had it replaced. My unit stopped cooling well during the middle of the day and we added some gas to it. Then, the...
When 13+ SEER condensers are replaced without installing a inside coil with an expansion valve the compressor in the new unit will slug and go bad. Slug means that liquid refrigerant returns to the compressor. Liquid can not be compressed so it causes the compressor to fail.
Jun 23, 2009 | Ruud UAMB Air Conditioner
3 Ton Ruud compressor
Is the unit over five years old? If so it is a fair price for conpressor, parts, labor and refrigerant. Have him give you a firm price. If it is an older unit, say over 10 years, and you have the money replace the complete system
Jun 15, 2009 | Ruud Handle Air Conditioner
Does my 10-seer have a 10 year compressor warranty?
If you take all the numbers off the compressor and condesning unit and call an authorized RUUD parts dealer in your area, they should be able to verify your inquiry.
Unless there was a special circumstance, most compressor warranties are 5 years, unless the compressor was replaced during the 5 year period, in which case you should get 5 more years assuming the service was performed by an authorized service company.
May 19, 2009 | Ruud Matching Split Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud Central System Air Conditioner Logo
75 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
