Question about HP 49g+ Calculator
When I try to turn on the calculator, nothing but a straight horizontal line appears on the screen.
    Sergeant:
    Champion:
  • 387 Answers
Hi
the HP 48g+ is similar to TI83 Plus
the same problem also in the TI its an hardware failure
if you want to fix the calc let me know
ecrdn@yahoo.com
Jack
Posted on Oct 23, 2010
Why does my SAMSUNG PLASMA have thin black line? horizontal line How to fix?
Sustain board fault. Contact any service technician. This is not a user repairable fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 02, 2014 | Samsung PN64D7000 3D Plasma TV
My ti-85 has missing pixels in the screen. What do I do?
Take it in for new screen,to be fitted,or by a new TV.
Jul 19, 2014 | Texas Instruments TI-85 Calculator
There's a blank bar that runs horizontal in the middle of my TI-84 plus that's about 16 pixels wide(high?). It's the same color as when the device is turned off. I've tried a memory reset and no results....
SPLIT SCREEN.
It sounds as if you might have split screen mode on. I've got a TI-83 as well as a TI-89 Titanium, both offer a split screen mode. The latter allows for choosing which applications are displayed on each half screen. I am presuming that you may have accidentally put your TI-84 in this mode.
So, if it is a split screen deal then all you have to do is go to the mode screen, find the option for switching from split screen to full screen, and switch it back to full.
I hope that helps. Give us your results!
Adios
Mar 11, 2011 | Texas Instruments TI-84 Plus Silver...
My TI-84 Plus Silver Edition Calculator is missing pixels or lines in the middle of the screen. If I press 2nd then + sign, i get menu to reset, but three lines are not visible. This happens in the...
this happand when you dont use the Calculator long time
try the 2nd and Arrow up make the screen dark for 15 to 30 min
keep puse any key until will pass the 30 min
if it will not help than it could be the screen or the connection on the mainboard
Oct 13, 2010 | Texas Instruments TI-84 Plus Silver...
My TI 86 is 6 years old and I have taken careof it well.
Try pressing (lightly) on the bottom border below the screen. If there is no change, try the top. If there is still no change, the power for your LCD may have become disconnected or shorted. There are external displays for these calculators intended for overhead projectors. If your school has one, you could try hooking it up to make sure the calculator itself still works.
In either case, it would be better to purchase a new calculator.
Good Luck!
Feb 05, 2010 | Texas Instruments TI-86 Calculator
Horizontal lines across whole screen
Bad inverter, or a dirty one. Remove the power cable and battery, then take apart the screen bezel, or casing. Remove the LCD by unhooking it. Disconnect the inverter. Clean it. Reconnect it. Fixed.
Feb 01, 2010 | ASUS Eee 1000H Notebook
One horizontal line across the screen
Read this article for troubleshooting.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
Screen not displaying whole letters because of horizontal and vertical lines
I've had the same problem. A temporary fix that I have found is to turn up the contrast all the way (press [2nd] then hold down the up arrow) until the screen becomes mostly black. Then turn the contrast back down (press [2nd] then hold down the down arrow) until it is at a normal level. If you can get rid of all the white lines when you turn up the contrast the screen will be back to normal. Unfortunately this does not permanently fix the problem because I cannot get rid of all the lines and it seems to be getting progressively worse each time it start up the calculator.
Oct 24, 2007 | Texas Instruments TI-83 Plus Calculator
Horizontal lines obstructing the second half of the ti 83 calculator screen, anyone know repair tips?
I had the same prob with vertical lines on the screen, and getting messed up when there was lots of numbers on the screen.
Solution: Change your batteries. Put some freshies in then adjust your contrast until you see the little black box. If you still have a problem with the lines, darken the screen until it's black (2nd up repeatedly) and let it sit for a couple minutes. Lighten your screen back to normal (2nd down) and turn off then turn her back on.
Jan 17, 2007 | Texas Instruments TI-83 Plus Calculator
HP 49g+ Calculator Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
