Question about Canon PIXMA MP530 All-In-One InkJet Printer
I have the same grinding scraping noise in my Canon mp530 as several others who posted here. Have you found a solution for the problem? The duplex function worked for a couple of years, but now chews up the page. Can you suggest a fix for this, also?
  • ventsue Aug 07, 2010
    I know how to clear paper jams. I need to know how to restore the duplex function.
  • ventsue Aug 08, 2010
    I need more info re the print carriage. Asked, but did not get response. Is it a fix that I can make? Is it a costly part, & how do I locate it? I find the Canon website not very user friendly.
  • 712 Answers
Open the set and see through all angles if there is any small bits of paper left in the printer. You should check carefully for it.
Best Regards.
Posted on Aug 09, 2010
  • ventsue Aug 10, 2010
    Sebin, By "set", do you mean printer? What areas in particular should I open?
  • Sebin Punnacheril
    Sebin Punnacheril Aug 13, 2010
    Do open every portion that you can to get maximum access to every parts of the printer. Be sure that you are able to place it back.
  • 10,515 Answers
The grinding noise pretty much means the print carriage is shot. Canon used to replace it for free but I've heard lately they're pretending they have never heard of the issue.
For the other part, let me know few details :-
1. Is it an intermittent problem or permanent?
2. It chews the page ONLY on duplex function or not?
Thanks!!
Posted on Aug 08, 2010
    Question re: print carriage. Is it an expensive part,
    Genius:
  • 1,478 Answers
Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear. To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out. Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
Try printing another document, if the problem still persist, you will need to replace the print head on your printer, the print head is worn out and will need to be replace to fix the problem, once this is replaced, the problem should solve.
Take care.
Posted on Aug 07, 2010
Can you do macs? how do i print duplex with this printer, duplex is suported by my mac
The Canon-supplied MP530 driver doesn't have duplex printing as a print option. Mac OS 10.5 has Gutenprint drivers built-in for a number of popular printers, including the Canon MP500 which is a near match for the MP530 and includes the two-sided option for printing.
With the MP530 plugged into your Mac (or, presumably, available over the network) go to the Add Printer wizard ( System Preferences > Print & Fax > + ). Pick MP530, name the printer something like "MP530 Gutenprint" and under "Print Using:" choose "Select a driver to use...", select "Canon PIXMA MP500 - Gutenprint v5.1.3" and then Add the printer.
The MP500 Gutenprint driver isn't a perfect substitute for the MP530 one, however, so you should do this in addition to installing the proper MP530 driver from the Canon website and adding the printer using that driver with a name like just "MP530" or "MP530 Canon". In a year or two of using the Gutenprint driver I've only once had a print job that wouldn't render correctly (some missing lines on the printout), and for that one time I had to switch to the Canon-supplied driver to get it to work. All the other times I find it very convenient to have two-sided printing available as an option.
The two sided printing isn't particularly fast, but it's a whole lot more convenient than manually printing the odd pages and then the even pages.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 28, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 grinding noise. Tried 2 solutions in this forum - didn't work. Noise happens when printer is idle, after printing. Print head (carriage?) tries to 'park' when noise happens.
Someone, somewhere, suggested removing the cartridges and then the printer head, putting them back, and unplugging and then rebooting the printer. I do believe this has solved my problem. I had been living with the horrid grinding sound for many months, and now it is gone. I am crossing my fingers that this will last, because otherwise it's been a great all-in-one.
Nov 11, 2010 | Canon PIXMA MP530 All-In-One InkJet...
My canon pixma mp530 makes a loud noise most times when it powers up and when i print a document. It works OK otherwise.
My MP-530 would try to boot up making a noise like something slipping or grinding, ending with ERROR Code 5100.
Solution: Open the Lid. The drive belt was loose and not able to drive the carriage. There is a gear on the right side of the carriage and a pulley on the left side of the carriage. The spring which holds the pulley tight is missing or broken. I was not able to see the tension spring. To put tension on the pulley, to tighten the drive belt, I cut a Popsicle stick into a wedge and inserted it into the middle slot right of the pulley.
Close the lid and power back on. Runs like new. Hope this helps.
Jul 31, 2009 | Canon PIXMA MP530 All-In-One InkJet...
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Jan 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Losing power and Grinding noise
whoever did the rear brakes either did not replace the hardware kit and something came lose or something just came loose. either way has to come apart repair whats broken. did you replace the drums.
Sep 17, 2008 | 2001 Pontiac Sunfire
Printing a book from Word using duplex printing
In the Printing Preferences window, on the Page Setup tab, you have already selected Duplex Printing and Automatic. If your book is to be bound on the long side, you should have 'Long-side stapling . . ' selected in the window below that.
If that is what you have selected and the pages are printing wrong, try the 'Short-side stapling . . .' option.
May 09, 2008 | Canon PIXMA® MP530 All-In-One Printer
DUPLEX PAPER JAM
I posted previously. After buying new paper, the duplex printing is working. It is probably heavier than my previous paper, but not particularly thick (don't know the exact grade.) So if you have this problem, try buying some new paper a little thicker than you are using now.
Apr 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 Makes Grinding Noise when printing starts
I had this same problem and called tech support. Instead of sending a new printer they had me
1 remove print Cartridges
2 remove print head
3 replace print head
4 replace print Cartridges
5 unplug power from the wall
This seemed to fix the problem.....for me anyway.....for now.
hope it helps
Dec 15, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Two-sided printing
On a PC...
- Ctrl + p to print
- Choose the Canon MP530 if it's not already selected
- Click Properties button
- Page Setup tab
- Select Duplex Printing
My paper always gets jammed, so I always uncheck the Automatic checkbox. Hopefully you won't have to do that.
Good luck.
Nov 13, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
71 people viewed this question
old marine
old marine
