Nu-wave spa hot tub controls. Nothing turns on and we have reset the GFI. It is plugged in. Is there a part on it similar to a electric dryer called a thermal limiter? Or what else could be the problem. No lights, nothing...When this occurred the water level was below the jets. Isthere a reset switch I cannot see. Where do I test for AC voltage?
exspert
  • 55 Answers
SOURCE: Dryer not turning on
ok " the timer has points that act like a switch , they get burt and will not work after a long time
replace time , it's just a plug in unit
Posted on Jan 21, 2008
SOURCE: I have a Carrier 38tra048340
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Posted on Jun 23, 2008
jbjaxiis
  • 95 Answers
SOURCE: GFI plug trips when pluged in, no reset
You are trying to draw too much power from the dedicated electrical line, or you may have an outlet that is needing replaced. Try to use another plug, in another room to test
Posted on Jul 21, 2008
meBNme
  • 334 Answers
SOURCE: Problem in the power Plug AC doesnt turn on
That means you have a short to ground somewhere in the system. They can be a pain to track down. You must have a volt/ohm meter and check each component and part individually untill you find the short.
There is a small chance that the GFCI is bad itself.(The part thats poping off and has the reset button.)
Posted on Dec 28, 2008
  • 360 Answers
SOURCE: GFI 'shorted'
load neutral connects to the neutral binding screw on the GFI, do NOT connect the load neutral to the neutral bar.
Posted on Mar 05, 2009
My hot tub works for about 20 mins and clicks the GFI off. Then I reset the GFI and the spa comes on for about 7 mns and trips the GFI again. Is this my heater doing this?
Easy way to test for the heater issue is to disconnect the heater from the board. Disconnect both leads from board and let the spa call for heat. There is also a chance the GFI breaker is bad however most times the heater fails and the breaker is doing its job.
Apr 01, 2017 | Hot Tub Works Pool & Spa
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
Is there a reset button
First, plug a fan or hair dryer into the plug to make sure it has power, if not, check to see if the GFI plug hasn tripped. All electrical plugs that are near water have to be on a dedicated electrical line that has a trip-breaker (GFI) built into the plug. Try unplugging the washer for several minutes to reset the electronics. Those are the only two quick fixes I can think of. If you have an electric dryer, it will have its own 220v plug and won't be affected like the washer. If the dryer is gas and is plugged into the same outlet, try unplugging the washer to reset first before you call a repairman for the washer. If you have homeowners insurance, they may cover the damage.
Jun 21, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
Electrical issue with Eclipse spa
most portable units have a gfi like unit on the control box..it is shaped like an outlet but without the prong holes for a plug to go in.. my tub has one..its got a black reset buttom and a red test button on it..push in on the red button.. if the black button does not pop out(you will hear a click) its already tripped..push in the black button.. if the tub starts to work then observe the functions.. if not recheck the breakers/fuses at your main box..now as far as tripping the gfi..you may need to dry the wet motor out using a blow dryer(for hair) but there is an earth ground on the control box that you need to connect a simple ground wire to a rod driven into the dirt close to the tub..(if its outside)..the power cord to the tub needs to be as large as your electric stove connector is..thats a 50 amp 220 volt setup..anything smaller wont properly run the tub..do not use any smaller wire as it will get too hot and eventually burn up..it becomes a safety issue..be carefull with all of this..
May 20, 2013 | Eclipse 4 Person Hot Tub Spa - Dream Maker...
Contactors on my nu wave 1000 spa control hot tub will not work
This means the contactor needs to be replaced. When they do not engage when power is put to them they are bad.
Rod
US Parts Center
888-521-6183
Feb 12, 2013 | Pool & Spa
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 02, 2012 | Electrical Supplies
40 amp gfi on hot tub keeps tripping.I have a 50 amp.can I use?
Your hot tub needs GFI protection because it is electrical, and people sit inside water that could be exposed to electric current.
You have a fault to ground that needs to be fixed.
Size 8 wire for 50Amp breaker.
Size 6 if tub is 50-100' feet away
http://waterheatertimer.org/Color-codewire.html
Nov 09, 2010 | Spa Parts Plus GFCI, Circuit Breaker, 40...
My hot tub i dont no how too turn it on or turn the heat up
There should be an independent circuit breaker to control the tub, most commonly a 50 amp GFCI breaker. (Has a "test" button on the breaker itself) It is usually located either in the vicinity of the spa in a gray box, or in the main circuit breaker panel of your home. In rare instances, they may have used a "fuseless disconnect" either in the spa equipment compartment, or within the vicinity of the spa. (at least 6 ft. away from spa) The disconnect is simply a removable lever that you pull out to disconnect power to spa. I would advise you search for a breaker or disconnect. If you locate the breaker, switch it off, then back on. If you locate a disconnect, pull it out, ensure that it is inserted in the correct way, then re-connect it. If that doesn't work, check for a GFI on the equipment pack itself. It would have a "test" and "reset" button on it. Press the test, then reset button. You should hear a distinct "click" when the test button is pressed, and the reset button should stay in once pressed after that. If it does test and reset properly and the pump, etc doesn't work, then you have a problem in the control pack. (Either a fuse, or a component that an average consumer cannot diagnose or repair.) That being the case, you should call a qualified spa technician. Hope this helps.
Dec 31, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Hot tub has power but nothing else works
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Oct 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
How to turn on hot tub
Check at the plug in if it has a normal plug like in your home first. Should be a set of buttons there, called a GFI. One is test, and the other reset.Push reset to see if spa comes on. Most spas dont have an actual on button. Check breaker box for popped breaker also, maybe tub is having problems, and needs a service call. Also larger tubs ussually jave a gfi or fuse box outside, close to tub. Kirk
Dec 01, 2008 | Pool & Spa
Heating & Cooling Logo
339 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
