Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Toro Lawn mower, 22" push mower
I have owned the above mower for approx 2 years, I use it about once a week during the summer and maybe twice a month during the winner, I have maintained it well, however the other day it started to act up on me.
The problem: It will easely start when it is cold, it will run normally for about 2-3 minutes, then it starts to sound as if it is runnig out of gas/fuel, then it stops, I am able to restart it a couple of times and it does the same but the hotter it gets the shorter the time it stays on until it just will not stay on at all.
What I have done: I empty the gas tank, pour fresh gas in it, it had a small foam filter which I replaced, air filter, spark plug and oil was all replaced, I even changed the blade for a brand new one, all OEM, the mower continues to do the same.
Can anyone help?
Thank you
Fonze
  • 2 more comments
  • Anonymous May 24, 2008
    1. I have the same lawnmower. Mine will start ok, but will not continue to run. It will continue to run if I press and hold the primer bulb on the carburator.
  • TUBBYS64 Jul 04, 2008
    I also have the same problem! I bought it used and filled it with gas/oil and it worked great the 1st time, when I tried to cut the grass the 2nd time I filled it up with premium gas and it started to stall out on me. I tried to adjust the screw above the primer thinking it was running richer but that didn't help, I also got a new plug and that also did not help? I have no idea where the gas filter is? PLEASE HELP
  • Chad Jul 09, 2013
    you should never use premium gas because ethanol will eat away at the internal parts of your carb. Always use 85 gas.
  • Chad Jul 09, 2013
    Use E85 gas. Premium gas has high levels of ethonal which will deteriate the inside of the carb.
It sounds like the small orifice in the fuel bowl is clogged. This could be from dirt or varnish that collect in the gasoline over the winter if you don't empty the tank and run the mover dry before storing. If you are not mechnically inclinded, take it to a dealer and they will clean out the fuel bowl. Easy 5 minuite job.
Posted on May 17, 2008
  • Al Mendoza Sep 09, 2010
    You were close. The problem was the gas cap, it was not letting the tank vent and it would cause a vacuum and the gasoline would stop going into the bowl. Overtime gas would slowly seep into the bowl and the mower would run until the bowl would empty.
Wheels are locked when trying to push it forward with engine shut off.
There should be a release to disengage the drive system so you can push it when not running. On my Cub Cadet it is on the back above the hitch. It is a simple lever that I pull out and push up to disengage. Has to be something similar on the toro.
May 02, 2016 | Toro Lawn Mower. 22 in. Personal Pace with...
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Toro choke doesn't work
try cleaning out the carburator.
May 23, 2017 | Toro Lawn Mower With Toro Power Tools
My ground speed is very slow can i adjust the travel pedal on my troy built 22 hp 46 in hydro lawn mower
I have the same machine, [pull plug wire for safety] tip machine on it's side, next remove blade, now remove all the plastic shields that are above blade right to the deck bottom. You wont believe the grass build up around blade shaft. On this machine as you select your speed the pulley travels on shaft, but with the grass build up the pulley can't move. I've done mine twice now in the last 4 years. You'll need around 3 hours, good luck it's not that bad.
Oct 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
What oil to I use in toro self propelled lawn mover is 5w30 ok
Hi jonconbuck...
5W30 is ok during the winter season...but use 10W30 or 30 W non detergent during the summer season
Please take time to rate me
Sep 11, 2011 | Toro Power Lawn Mower
I have a 2010, 22" Toro Recycler which has broken
I would take it back to where you bought it and demand they fix it under warranty and show you the proper way to stop it. Sounds like it was improperly set-up.
Jul 11, 2011 | Toro Power Lawn Mower
My toro self propelled lawn mower won't roll backwards... the wheels are locked up
My Toro Pace Master self propelled 22" 6.75 mower will not move by itself. I can push the mower and cut. It does start with no problem. I have a cable on left side of the mower that extends to the top of the handle broken off at the top of the mower and is loose. Is there a way to check to see if this is why it will not self propel. It attaches to the push handle that does I push down to propel the mower. Any suggestions?
May 07, 2010 | Toro Lawn Mower With Toro Power Tools
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
206 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
