Question about Kenmore Dryers
The burner egnites during the enitial start up, but does not re-egnite during the dry cycle. clothes stay damp.
    President:
  • 1,430 Answers
The problem is the dryer coils are failing. They tend to fail as they heat up. They are easy to replace and inexpensive. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Posted on Aug 07, 2010
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Egnition lcoked
As you turn your key to start, at the same time move your steering wheel side to side until it unlocks
Jan 17, 2013 | 2004 Ford Escape
Cannot turn the ignition. it just won't turn. the wheel's not locked up but the ignition is.
i have done this before an it worked so u could try it take a socket close to the size of the egnition an a hammer remove key fist an drive it home an then try key again if it doesnt work replace egnition if it does work dont remove key till u ready to replace egnition
Dec 20, 2010 | Chrysler 300M Cars & Trucks
I have a whirlpool gas dryer model LGQ9508PW0. It is not drying. I noticed that it would egnited the firest time but not after that. I replaced the egniter thing it was worn. Now WITH NOTHING IN IT it I...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 24, 2010 | Whirlpool Dryers
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Egnition is deadlli
Does this mean that it will not crank, or that it cranks but does not start??? Check small ground wire from battery to fender to make sure its not broken.
Jul 24, 2009 | Chevrolet R10 Cars & Trucks
1985 Ford Ranger will not start when damp and cool outside.
possibly distributor cap getting wet. Try this. When it's not starting, remove distributor cap and dry inside and outside with hair dryer on warm setting. See if it starts then. If yes, replace cap and rotor and make sure plug wires are clean.
If it still doesn't start, you may be getting mositure in a wire connector that operates spark to plugs.
Are you getting spark at plugs when it own't start?
Check by getting a spark plug and plugging a spark plug wire into it and grounding the side of the plug. crank engine and watch for spark at gap.
May 25, 2009 | 1985 Ford Ranger
Pilot light will not stay on when egnition switched is released!
the little copper tube that sits in the pilot flame is faulty. this is called a flame sensor. replace this and you should have no problems
Dec 03, 2007 | Empire ECS HB06M HearthRite Heater
Dryers Logo
29 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
