Question about GE WBSR3140DW Top Load Washer
My GE Top loader washer seems like it will not fill up with enough water to move on the next step in the cycle unless I put it on small load then it starts on the next cycle but runs out of water and starts back puting water in. Is there anyway I can fix that or do I have to get another washer.
    President:
  • 1,430 Answers
First make sure the screens in the hoses and the water inlet valve are clean and you have good water flow. Here is a link for checking the water inlet valve screens http://appliancehelponline.com/topwaterinletvideo.html
Now if water flow is not the problem the problem is going to be the pressure switch. Here is a link for that http://appliancehelponline.com/toppressureswitchvideo.html
Both repairs are easy and inexpensive to repair.
Posted on Aug 07, 2010
Why does my front load washer not fill up with water like top load washers
Most modern washers use little water. Let it do a wash cycle and see if the results are satisfactory. If not good enough there is a way to allow more water to be used. Give it a go first.
Aug 29, 2014 | Whirlpool duet Washing Machines
Ge toploader whse5240D1WW will not fill with water
please the causes and remedies: God bless you
f your Top Load Washer Has No Water Entering Check The Following
Water Inlet Valve
First check the hoses that connect to the water inlet valve. Remove these completely there should be a screen in at least one end and maybe both ends. Clean these screens. Next check the back of the water inlet valve screens and remove and clean. If cleaning these out does not correct the problem you will need to check to make sure you have power going to the water inlet valve. Most top loaders will have 120 volts going to the valve. Check each solenoid on the valve. You will need to have the washer on and turned to a fill cycle when checking. If you have power and still no water replace the water inlet valve. No power replace the control.
Control / Timer
This is less likely the problem but can fail. If you have no power going to the water inlet valve when selecting a fill cycle the timer/ control has failed and you will need to replace the timer.
Jul 18, 2012 | GE WHSE5240D Top Load Washer
Top loading GE color profile washer (wpse4200a) won't fill
You may have a water supply problem. There is a mesh screen in the hoses where they hook to the washer. Make sure they aren't clogged up
Sep 19, 2009 | Washing Machines
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile will not run cycles. Runs water continuously.
OK, i would do a hard reset by unplugging for 2 minutes. if the problem still exists, this is defiantly a malfunctioning relay. it will have to be replaced.
Mar 06, 2009 | GE Profile WPRE6100G Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Overflowed on Large load size
i think the water level sensor tube got filled when you had it on it's side, then after the first spin and drain cycle, the tube was again cleared out and ready for real action.
Oct 29, 2007 | GE WJSR1070A Top Load Washer
GE WBSR3140DW Top Load Washer Logo
122 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
