Question about Bryant Heating & Cooling
I have a Bryant Heating/Cooling unit. Serial # 4698E18469, Model # 597CN042-D. The water pump that pumps condensate out was replaced last weekend. A couple days ago, we stopped getting air flow. I replaced the filter, but the house still isn't cooling. I think there is more air flow, but it's not cold air. I'm not certain how to check the condensor or even if this is the first place I should look. Any advice? Thank you for your help! Rena
    Genius:
  • 1,478 Answers
Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas: Compressor Condenser Evaporator These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components. If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas: Compressor Overload and/or relay Thermostat (Open thermostat) Burnt wiring Bad selector switch Capacitor.
The condensing coils will always be on the "warm" side of the air conditioner. That is, on the side that faces outside of the room to be cooled. Air is drawn into the back of the air conditioner on the sides through vent slots and is blown directly out through the condenser coils. If the coils get clogged with lint, dust and dirt the cooling system cannot provide the cooling necessary. To clean the coils it will be necessary to remove the entire cover of the air conditioner or pull it out of the wall to gain access to the coils. They can be cleaned by blowing compressed air at them or by using a soft bristle brush to wipe the dirt off. It is important to also clean any dirt or lint build-up in the bottom of the air conditioner so the condensate water will be picked up by the condensing fan slinger properly.
Take care.
Posted on Aug 07, 2010
Bryant AC Model: 165ANA018-B - Circuit Board: HK38EA004 has [Y.C.R.LS] my 3 wires are Green, Red, White. How to connect back again?
You need to check at the indoor unit to see how the condenser wire is wired in. Remember. just because a wire is red does not mean it goes to R. Your three connections will go to R, C & Y but no one could tell you what color goes where without looking at your inside unit.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 27, 2018 | Bryant Heating & Cooling
Bryant/Carrier Roof mount heat pump 664ANX042000AAAF wiring diagram and capacitor help. Which capacitor is for inside blower motor?
typically a cap for a blower motor is a single purpose capacitor where as the condenser side would be a dual purpose capacitor. 3 sets of plugs for dual, 2 sets of plugs for a single. Hope this helps.
May 08, 2018 | Heating & Cooling
Model numbers for Bryant AC difference between a model pa4zna048 & a rspma48
The difference is the sticker on the outside of the unit and the slightly higher price for parts on the Bryant. Go with the Rheem but don't be mad at me when it breaks down, the Bryant will too. Honestly it's luck!!!
Aug 30, 2017 | Bryant Heating & Cooling
Gshi30251ab model/ 0701186874 serial is this a hvac unit or a heat pump
Hey Tabatha.... its all "HVAC" -
H = Heating
V = Ventilation
AC = Air Conditioning
Heat pumps are the norm now... Up north there are furnaces and separate A/C units... in the south, its all heat pumps..
Hope this helps...
Aug 29, 2017 | Heating & Cooling
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
When condensate water pump must run in LG cassette unit.
There is 2 float switches inside the drain pan. One turns on the pump when water gets to a certain level, one shuts the system down if water gets up to that one.
Apr 13, 2017 | LG Heating & Cooling
I have a Bryant heating/cooling w/ heat pump - E3 error on thermostat and the house is 61 degrees and smells of burnt air
I asked Mr. Google " carrier e3 error code", and I found this.
The outdoor thermostat is in error, not connected, or shorted out. This code is displayed only if auxiliary heat and/or cool lockout feature is enabled.
What this means is that your o.d. unit has a component failure. The smeel you have inside is probably you electric heat elements that are energized. And if they haven't been energized in a while, its burning off some debris.
Mar 07, 2017 | Bryant Heating & Cooling
Where are the schematic for Bryant heating condenser model #986TB ?
most schematics are found on the inside panel where components are located
Jan 12, 2017 | Bryant Heating & Cooling
Hi We have just arrived back in Wellington from overseas. Our house has a gas central heating system - the unit is Brivis Buffalo 20. What we would like to know is how cost effective the Brivis Buffalo 20...
Hi, if you are planning to change this system out, please stay with a gas fired central system as compared to a heat pump, they are much more cost effective. Heat-pumps have so many problems as there are more parts on them to go wrong. The compressor and condenser fan motor run year around as with a heat-pump they use what is called a reversing valve that changes the flow of freon making the indoor coil the outdoor coil and the same with the outdoor coil becomes the indoor coil in the winter season. I can recommend excellent gas fired units compared to the Brivis unit you have that is much more cost effective, such as the Bryant, Carrier, Goodman. I would go with a Bryant and talk to a dealer. Stay away from a heat-pump no matter what they tell you as I have worked on them for many years and if you have gas available, stay with gas. You will heat your home much faster and save on electricity as this heat -pump units need heat strips for back up heat as they can't keep up the temperature with out them. I hope I have been of help to you on this, and you will be kind when rating me as I know you will. Please contact a Bryant dealer as you will not regret it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Sep 05, 2010 | Heating & Cooling
Bryant a/c heat pump "model 540bj024"
Check if you have 24volt out of the board if not replace it.
Feb 22, 2009 | Bryant 463AAC008BA Air Conditioner
Heating & Cooling Logo
94 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
