Paper jam hp 1020 printer - Office Equipment & Supplies
  • 1 more comment
  • ladyjb Sep 30, 2008
    all of a sudden my printer will jam. You hear a rapping sound when the paper is trying to go thru. It will push up but then will stop. Toner is all over the left and right sides of the paper that is pulled out. Any suggestions
  • tchristel Dec 08, 2008
    the paper crinkled inside the left-hand side. How can I open the machine to get it out?
  • eddybear01 Apr 19, 2009
    I have a Officejet 6210 All in one and the paper just stated to jam up!!!! It always worked well before. I dont Know what to do I need these invites out today can some one please help?
  • 1,342 Answers
  • 4402 Answers
SOURCE: HP LJ 1020 Output Page Jams @ Fuser input
either your fuser is bad or output rollers, I put my money on the fuser
Posted on Mar 26, 2008
  • 9 Answers
SOURCE: Paper Jam HP LaserJet 1020
Papper never realy "jams" the problene is usualy that the paper is late reaching the next paper sensor. What i would sugest is that you clean the paper pickup roller it is usualy in the shape of a D. Clean it with dishwassing soap dont use water just clean soap rub it on with a clean cloth until the roller is dry so use a small amount. This should solve your prbleme.
Posted on Jul 04, 2008
  • 25 Answers
SOURCE: Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it around so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you.
Figure 2: Removing the rear access door
  1. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  2. From the rear access door opening, remove the jammed paper.
  3. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the unit and turn the unit on.
Preventing paper jams
The following information will help prevent paper jams from occurring:
  • Never use paper that is torn or wrinkled.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with new paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door is not locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Posted on Jul 08, 2008
  • 435 Answers
SOURCE: paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
Posted on Oct 20, 2008
  • 114 Answers
SOURCE: Paper jam on HP officejet 6500
Try This :
Connect the printer directly to the wall outlet ; not through any Power strip
Then Unplug the Power cable from the back of the printer
Keep on tapping the power cable for next 30 seconds
Plug in back the power cable;
Open the rear access door and you will get to see some rollers
Clean the rollers with a Lint free cloth Moistened with some distilled water
Try to do a copy if still it doesn works
With one hand press and hold down the (#) and the (6) button and with the other hand plug in back the power cable ; it will do a Semifull reset on the printer; This will take some time ; Follow the instruction on the screen;
If still it doesn't work then you need to contact HP ;
The toll free no. for HP would be : 1-800-474-6836
They will replace the printer for you free of cost (No Charge if the printer is in warranty i.e within 1 yr of purchase)
Still you may check the link below for further issues:
Regards Soumajit
Posted on Sep 21, 2009
Paper jam in hp laser Jet 1020 printer
I suggest You Please Watch Below YouTube Link URL To Fix Your HP Printer Error:
In case You still need Online Support For Hp Printer Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet 1020 Printer
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
1020 hp printer problems
I would advise also opening the door on the back of the printer (if this printer has one), removing any paper trays and cartridges too. All of these can obscure places where paper can jam. Be thorough as even the tiniest scrap can cover a vital sensor.
Sep 06, 2012 | HP LaserJet 1020 Printer
Printer hp 1020 in it when we print command of more then two paper the second paper jam (half inside and half out paper does not reach to Teflon part section . single paper printing is OK no pro....
Clean the Paper Feed Rollers with wet cloth.Then go to start-ControlPanel-Printers-select Hp1020 printer-properties-features-change the Paper Type as PLAIN PAPER.
May 23, 2011 | HP LaserJet 1020 Printer
Hp laserjet 1020 thinks it's jammed but it's not
you will have to first disconnect the printer cable and eject the paper from printer tray.
after you should be delete the pending document and uninstall and reilnstall the printer.
best of luck
Aug 30, 2009 | HP LaserJet 1020 Printer
IN my office I have HP Laser Jet 1020 plus, A4 paper got jam
you need to deassembly the printer by removing back screws adnd open cover to access fuser unit.
Jun 26, 2009 | HP LaserJet 1020 Printer
I had a paper jam..took out the cartridge..pulled
Hello sir;Track back the paper you pull through you will find a senser either stuck or come off, put it back property.
May 06, 2009 | HP LaserJet 1020 Printer
Hp laserjet 1020 keeps jamming paper
It is not exactly very easy to get to that area. I found some service information at the HP site. Here is the link to it.
Select course #23875 then under the 1020 select service and then paper pickoff assembly. It gives you a visual course on how to go about opening up the printer to get to that area.
Let me know how you fare.
Dec 31, 2008 | HP LaserJet 1020 Printer
Problem with HP LaserJet 1020 Printer
Hi all of you
  1. check paper sensor.
  2. check that return every thing proper cartridge and the door.
  3. move the gear system manually.
Hope this fix your problem,
Nov 17, 2008 | HP LaserJet 1020 Printer
Paper out jam in hp laserjet 1020
Thank You
Oct 20, 2008 | HP LaserJet 1020 Printer
1,038 people viewed this question
