Question about Kenmore 24 in. 16482 / 16484 / 16489 Built-in Dishwasher
My kenmore 16482 dishwasher was noisy and not cleaning very well. I removed the large motor underneath and found what looks like the plastic pieces that are on the electric motor shredded and worn and possibly some worn plastic in what im guessing is the pump housing. can these parts be serviced separate from the motor and where can i get them? thanks in advance
  • 1462 Answers
SOURCE: Standing water in the bottom
try starting any program - all start with drain. if it doesnt drain, suspect a foreign object in the drain pump
Posted on Mar 29, 2007
SOURCE: The "spinner, 3rd level wash" kept falling off. Ordered new part, no instructions with it.
I came here today looking for the solution to this same problem! However, I might be able to help a little...in searching the bottom of the dishwasher, I found the pointed plastic piece for mine. To put it back in, here's what I did -- the 'vanes' of the spinner face the top of the dishwasher, align the center hole of the spinner with the hole in the 'ceiling' of the dishwasher. Push the small plastic piece (pointed end up) up through the center of the spinner and snap it into place, attaching it to the dishwasher. However, whenever I put mine back in, it comes out in the next wash. I'm assuming that my spinner keeps coming out because my plastic piece is worn(?) I was wondering if there was a screw involved to hold it into place, but from your description of the parts bag (spinner and plastic snap) perhaps there is not. I'll order my replacement part and see if that fixes it. Anyone who knows about this for sure -- please post for us! Thanks!
Posted on May 14, 2007
  • 3 Answers
SOURCE: PARTS BREAKDOWN OF KENMORE ELITE DISHWASHER
we have located a spring down deep just below the grinding propeller it was twisted and unwound rubbing ageinst the top of the grinder we have removed the pesky sping and are ordering a new one motor is not making any noise now that we have removed this spring. hope this helps you too...
Posted on Mar 17, 2008
  • 833 Answers
SOURCE: Kenmore quiet guard 4 dishwasher, is making a humming noise
Generally, the filters are removable.  You'll need your manual.  Nothing can get into the motor...but they can get into the pump.  Remove all the racks, get in there and find the item...likely a small bone or toothpick or that plastic bread closer.
Posted on Nov 20, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
Kenmore elite powerwash dishwasher cycle stopped due to not enough water
I just had this problem and it was bad. No matter what I did, the DW would not run. Finally, I found and checked the float switch. Actually, I didn't even know what a float switch looks like. Fortunately, I found a YouTube video that showed what a float switch looks like. My float switch was actually fine. However, a small piece of plastic had gotten jammed under it. I removed the piece of plastic and now everything works. Really easy to resolve in my case.
May 29, 2012 | Kenmore 24 in. 15689 Built-in Dishwasher
Leaking dishwasher
1-if it is brand new it should be under warranty 2-try changing soap brand, some suds up more than others and sneak past the seals 3- where is it leaking? (around the door, or underneath ie likely motor seal or plumbing) 4- check Plumbing connections 5-most "tubs" nowadays are one piece plastic, look it over carefully with a good flashlight. if you think you have found a crack remember where it is start the dishwasher and run it till it starts leaking and then open it and examine that spot-with the heat it may open up more or otherwise change
Apr 08, 2012 | Kenmore Dishwashers
Kenmore washer will not spin moved out and underneath found a wagon wheel shaped black thing with four small plastic white parts?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Dec 29, 2010 | Washing Machines
My kenmoore 70 series washer will not agitate, fills up and makes an awful noise,,,looked underneath for belts and coulnd't find any? Can you help?
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts. Look at the section chowing the motor, gearcase etc.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission. It's used as a fail safe device and consists of three parts. Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
Oct 12, 2009 | Kenmore Washing Machines
Dishwasher appears to be having problems draining - loud screatching noise and sound like metal clanking
Either a piece of tableware has penetrated the intake screen at the bottom under the lower spray arm, and the pump impeller is damaged, or the pump motor underneath the deck has a bad bearing and must be replaced. Remove all components including the lower spray arm down to the bottom deck. Note the position and orientation of each piece as it is removed. When you get to the bottom, there should be a pump impeller that is connected to the motor underneath the deck. Turn the impeller by hand and see if it is noisy, or moves side to side indicating a bad motor bearing.
Sep 07, 2009 | Dishwashers
Noisy cycle and dirty dishes
Hi
If your dishwasher seems noisy, check these:
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Please accept the solution and revert for any further assistance.
Thanks
Rylee
Mar 25, 2009 | Kenmore 24 in. 17362 / 17364 / 17369...
Nov 17, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Elite Dishwasher - leaks from Overfill Protection Float
I had the same problem, but mine leaked every time. I have a kenmore ultra wash dishwasher no. 665.15762. I took the bottom rotating sprayer off and found that the plastic piece under the sprayer had a few loose screws and the rubber gasket, under that piece, had blown out at the corner facing the overfill protection float. I took out all the screws and re-mounted the gasket in place and put all the screws back and tightened them. It solved the problem. I hope that this helps others.
Nov 11, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Kenmore built in dishwasher~2001 model year ,noisey when running.
HI remove the spray tube. remove top cover. look inside that could be a broken piece. this patr can break with pieces of glass going through it. thanks
Oct 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Permanent (?) stains on inside of door
Have you tried a treatment (not sure of the name) that you wash plastic dishes with that takes the orange stains out? It can be found at Walmart for under $10. I don't know of anything that can prevent this problem but I don't see why a product that takes it out of plastic dishes can't take it off the plastic of the dishwasher. Hope it helps!
Sep 05, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 16482 / 16484 / 16489 Built-in Dishwasher Logo
225 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
