Question about Compaq Presario 700 470024-192 Notebook
Display went dark - Compaq Presario 700 470024-192 Notebook
  • 22 Answers
Does your system start up with sound ? I would guess it is and that you have a bad LCD screen. If you post a little more of what is going on, I'll be glad to help.
Posted on Aug 11, 2010
Display went dark/black- symptoms point to T-con board but after 20 minutes, display lit up for 2 minutes then went dark again. Same thing happened again after next 20. After 60, display stayed on
I was a Samsung tech for 3 years, and T-cons are a common problem. But it sounds like a loose wire to the T-con, I have came across the same issue in the field. I would break it apart and look for a loose connection.
Thanks,
Jason
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Jun 24, 2016 | Samsung UN39FH5000FXZA - 39in 1080p 240...
At start up my viewsonic va1912wb display blinks several times then i can see the picture but it is dark almost unreadable. Today it went darker than yesterday. HELP!
If it is dark due to brightness adjustment, get that adjusted. Usually when you adjust the brightness by pressing the menu button, the menu screen would not be dark. If everything is dark dark dark and you can only see some display but in very pitch darkness, then your monitor is a goner, backlit for the monitor is dead, and your monitor will need to be replaced. You can fix the backlit tubing, however it is risky, and expensive, and would cost less if you bought a replacement.
Jan 30, 2011 | Computers & Internet
After working normally for several years, my Inspiron 1100 display went dark but will come on normally if I press Fn+CRT/LCD BUT ONLY FOR 1 OR 2 SECONDS then goes dark again. Tried holding F8 during...
there is a ribbon cable going from the lower [keyboard unit] to the upper unit [display] that has been going bad over time. or the display panel backlight is bad.. you might be able to save old betsy by taking her to a laptop shop and see what they can do..goodday
Nov 09, 2009 | Dell Inspiron 1100 Notebook
Monitor went dark
Most probably the memory module(RAM) has gone bad. With a bad ram no display comes on monitor. Change the RAM and see the result.
Dec 17, 2008 | E-Machines eMachines Desktop PC
Display after rain went black
If your video output works fine when connected to an external monitor, then the issue is with the LCD display panel. I’m afraid the only way to fix this is to have the LCD panel replaced.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 6400 Notebook
Display panel stays dark.
this might be due to the fault of the cable attaching to display panel, check it by some hardware engineer near you
Sep 28, 2008 | ASUS Eee 4G Notebook
LCD Monitor went Dark
hi bear2243055
I suggest reinstalling your graphics device drivers and maybe the game as well.
May 08, 2008 | Samsung SyncMaster 931B 19" LCD Monitor
LED display on powershot a630 is very dark. It was working fine, and then when I moved the display it suddenly went dark
pershaps that the cable inside to power the lcd is defect. or it could also be that the backlight is defect . those things can be repaired (don't do it your self) but costs could well be higher than buying a new camera
Mar 22, 2008 | Canon PowerShot A520 Digital Camera
Laptop lcd display
sounds like your screen went out, if you need to access whats on your laptop real soon try hooking it up to a desktop monitor via rgb cavble.
Dec 13, 2007 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
