Question about Kenmore 23822 Top Load Washer
The commercial dryer doesn't heat - Kenmore 23822 Top Load Washer
  • Kenmore Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Apr 02, 2011
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Dryer has no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
May 21, 2011 | Whirlpool CEM2750KQ Electric Commercial...
No heat
heatman101
Jan 12, 2011 | Maytag MED5770TQ Electric Commercial Dryer
What do I do if my dryer runs, but does not heat?
Hello my name is Heath the problem is probably a bad heating element. If the dryer runs but does not heat then the heating element is bad and will need to be replaced.
Apr 07, 2010 | GE DDC4400S Electric Commercial Dryer
Can I run my Whirlpool HD Commercial Dryer on a 120/208 supply
you should change your heating element to a 208v element. go to your local appliance service depot and ask for 208 element for whirlpool commercial dryer and they will know what your asking for.
Dec 04, 2009 | Whirlpool CEM2760KQ Electric Dryer
No heat
If the unit is running but you are gettin no heat at all, you're heating element needs to be replaced.
Hope this helps...
Sep 14, 2009 | Kenmore 60172 Electric Commercial Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool commercial gas dryer - heating problem
Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
Feb 14, 2009 | Whirlpool CSP2761 Gas Commercial Dryer
Kenmore 23822 Top Load Washer Logo
14 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
