Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Washing machine stopped filling up and an error 43 or 43 came up on screen
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now Error code 43 means you have an OUT OF BALANCE SWITCH FAULT.The switch is located under the control module which is located under the top panel.Would you like me to guide you throe the testing and possible replacement of the Switch?The secondary source of this error code is your Motor Controller.But we must test the switch 1st as the switch is the most likely component that is faulty.Have you or can you borrow an electrical test meter to test the switch.It would make it easier to test the switch with the tester but there are ways around this.Please reply for further assistance and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Aug 07, 2010
  • 1 more comment
  • xx7grant7x Aug 25, 2010
    I am having the same problem and have access to such tools. can you guide me through?
  • luisa_sgro Aug 27, 2010
    Hi Grant just found your posting.Now 1st undo the 2 screws holding down the top panel of the machine.Make sure you turn the power off 1st.Now once the screws are removed lift the top panel off slowly as there will be a wiring harness attached to the display module.You should see a brown computer.Under the computer to the right should be the out of balance switch.If there is no switch there then you will have the model where the out of balance detector is attached to the motor.Please reply and confirm if you have the switch that is located under the computer.Looking forward to your reply.
  • Taina Van der Saag Nov 21, 2011
    hi, i have the same problem, it definately was out of balance as i washed a doona in it. switch is located under the computer. please help!!!
I have a washer FAFW4011LWO model number and it turns on and starts filling with water and stops after 3 seconds. I have replaced the door lock and it is still doing it. Any ideas?
maybe plugged screens in fill valve
ck here.....
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/43-2-832628-/new/Frigidaire-Washer-fills-slowly-or-will-not-fill-at-all-FAFW4011LW0
Jan 05, 2018 | Washing Machines
I have a bosch logixx sensitive washing machine code F:43 is displaying what does it mean
Hi there. After doing some research, I've discovered you need to either reset the machine by doing various on/off/pause/spin actions in a certain sequence (the sequence depends on your E-Nr number), or that there is a problem with the main control board.
Oct 11, 2013 | Washing Machines
WHAT MEANS F-43 ON THE SCREEN
According to the service manual, F-43 flashes if the motor control detects a low voltage condition. This error code could also be caused by poor air flow, loose wiring harness or a malfunction of the electronic control board.
You can disconnect the vent hose from the back of the dryer & compare that airflow to the airflow at the outside damper, they should be almost the same.
For the other checks I would recommend calling a service technician to diagnose & repair.
Feb 10, 2012 | Washing Machines
Fp excellence 7.5kg starts filling then stops, tries again a few times shorter each time and then errors with following led pattern: 00101011. We have levelled and tried over and over again, very...
Fault code 43
OOB switch error (out of balance)
CHeck Bowl Is Balanced Check Bias Spring is keeing bowl central
Most Likely Cause Corred terminals on Out Of balnce micro-switch
Jan 01, 2011 | Fisher and Paykel (IWL12)
Code 43
Error code 43 indicates that the washer is 'out of balance' . The switch is under the motor controller board. This is accessed by removing the 2 screws at rear of facia and exposing the motor board which is attached to the hob. The micro switch might be probably the faulty one. When replacing the switch make sure it's the same as the one coming off as they can be opposite function. Sometimes the oob arm below the oob switch can get jammed over the edge of the bowl and result in the same fault.
Thank you !!
Jun 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
Error Code E70
water fill problem ,,,check fill hose for kink,,,or lost of water pressure,,,you may need to clean inlet vavle screens..onthejob
Dec 20, 2008 | Frigidaire Affinity ATF7000E Front Load...
Pump stops and starts, water filling stops and starts
43. (00101011) OOB Switch Fault will cause stopping and starting on filling.Can you post what lights come up 1s represent on 0 equal off.
Jun 23, 2008 | Washing Machines
Error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
Mar 23, 2008 | Fisher Paykel Eco IWL16
Washing Machines Logo
601 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
