Question about Apple iPod nano
My itunes won't detect my ipod nano 4gb
Im using windows xp at the moment. my itunes use to be able to detect my ipod nano but all of a sudden its stopped doing it. from what i gather i dont think the usb port is detecting it because i tried using my friends usb cable and it still wont detect it. However i used my ipod speakers to charge it and it's able to detect it, so i dont know what's wrong with it, please help:(
x
My Ipod Wont Turn On And When I Plug It Into The Computer It Isnt Detected But Yesterday I Was Playing Games On.Now it Wont Turn On
HELP!
  • tonyajs Apr 28, 2008
    Mine is a 2gb, it wont turn on, it is not detected by Itunes. Please help.
    Tony
Hi my name is silvana, i want to know how to download music to my ipod nano
Posted on May 19, 2008
4 Suggested Answers
SOURCE: My itunes won't detect my ipod nano 4gb
well sometimes what people do is that they plug in the usb cable before the computer is on and it wont recognize the ipod. You have to turn off the computer and wait till it is on and then plug it in.
Posted on Jun 24, 2008
Thanks Kafrinn. I had the same problem & did what you said, it directly got fixed :)
Posted on Aug 11, 2008
mneilsen2084
  • 342 Answers
You most likely will have to put the ipod into disc mode and restore it. But heres a few things you can attempt
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
How to restore iPod (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on May 27, 2009
I have a 5th generation iPod Nano. I've had it less than one year, and now whenever I plug it into my computer with the USB cord that came with it, my computer says "USB device not recognized" and that the...
  • Check system requirements. - iPod nano (5th generation) requires the following minimum versions of Windows: either Windows XP (Service Pack 3 or later), Vista or Windows 7. If you have one of these versions of Windows, verify that Windows is fully up to date by downloading and installing software updates from Microsoft. If you have Windows XP with Windows XP Service Pack 1 or Windows XP Service Pack 2, download and install Service Pack 3 using Windows Update.
  • iTunes online? - Confirm that iTunes has been downloaded and installed.
  • AMDS online? - iPod nano requires Apple Mobile Device Support (AMDS), which should be automatically installed with iTunes. To verify whether it is installed, click Start > Control Panel. Open the Add or Remove Programs control panel and verify that Apple Mobile Device Support is visible in the list of currently installed programs. If it is not, remove and reinstall iTunes.
  • Check USB connection. - Disconnect all USB devices from the system with the exception of the iPod nano and any USB keyboard and mouse. Then restart your computer. Verify that you are using a high-powered USB 2.0 port. Test with an alternate iPod USB cable if one is available.
  • AMDS - Re-verify that AMDS is running and installed.
  • iTunes usage - Remove and reinstall iTunes.
hope this helps
Oct 14, 2010 | Audio Players & Recorders
I charged my 4gb nano 3rd gen ipod, but it won,t
slide the hold switch on and off a couple of times...then press and hold menu and center buttons till an apple logo comes on screen...connect to system and restore with itunes.
Sep 10, 2009 | Apple iPod nano
How do i put movies or videos in my ipod 4GB?????? plz
only 3rd generation iPod nanos can play video, and the video must be mp4, you can use itunes to sync video to ipod nano, just follow those steps:
1. Open iTunes and click "File" to add your videos to iTunes library.
2. plug in your iPod Nano to computer, then iTunes will detect your iPod Nano as a device.
3. Select your iPod Nano device on the left panel of iTunes, click "Movies" tab, check the videos you want to sync and click "Apply"
Jul 22, 2009 | Apple iPod nano
Jan 24, 2009 | Apple iPod nano
Jun 21, 2008 | Apple iPod nano 3rd Generation
IPod Nano 4GB and computer with Windows 2000 Pro
so it complains that your itunes is too old?
try one of these,,
http://www.oldapps.com/itunes.htm
May 09, 2008 | Apple iPod nano
hey, select your model from this webpage and do all the steps it suggests.
If after all that the ipod still doesnt work properly contact apple or your dealer for more help.
http://www.apple.com/support/ipod/five_rs/
Mar 17, 2008 | Apple iPod MA446LL/A MP3 Player
disconect your ipod
click the menu and the center button at the same time and hold it for about ten seconds to refresh it
after you ipod turns on again
reconnect it
and itunes should be recongnise it
Feb 02, 2008 | Apple iPod nano
My nano won't restore.
Try putting the ipod in disk mode by pressing the center and play buttons after resetting it (by holding down the center and menu buttons). You will know it is in disk mode when it shows a check mark on the ipod screen. Then plug it into your vcomputer and format it using windows.
After you format the ipod, try disconnecting and reconnecting to the computer and restore and see if that fixes your problem.
Jan 30, 2008 | Apple iPod nano
Apple iPod nano Logo
149 people viewed this question
Top Apple Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
mac colar
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
