Have older Panasonic Big Screen and in the settings somehow - when you turn the set on the video is fine and after bout 10 seconds a big black box appears in front of the show - how can I fix
    President:
  • 2,030 Answers
Thats a bad circuit in the main video board, once it warms up the short appears and it sends a bad signal to the circuits that control the on screen options menu. There is no fix for it unless you can find an old working main board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 07, 2010
Picture has a black image (box that black out part of the screen) that comes on seconds after TV is turned on, leaves when volume is adjusted, then returns after a few seconds. Does not appear when Wii is...
You need to go into your menu and go to close caption and turn off the text screen that some how got turn on, that big black box is call a text screen, and you are not the first person that this has happen too, Take care.
Jan 09, 2011 | Panasonic PT-51HX41 51" Rear Projection...
Toshiba big tv. Comes on fine nice picutre. about 10 seconds after turn on a "black rectangle" appears in the lower half of the screen
Chances are it's just the closed captioning is turned on and set for "text" mode. Use the remote to go through the caption settings until it's turned off and that should clear up the box.
I've written a tip that explains what's happened and how to take care of the problem.
Feb 24, 2010 | Toshiba 32A33 32" TV
My 32 lcd tv a black rectangle apears on aprox,
If it is a large black rectangle that blots out the middle of the screen then you need to check your CC (closed caption) setting. Make sure the closed caption is turned off. I'm not up to date on the newer sets, but a lot of the older ones had more than one CC setting. One setting ran the captioning across the bottom, another put it in a big black box in the center of the screen. Most places didn't support the full text so all that showed was a big black rectangle on the screen. Since I'm not sure exactly what your rectangle looks like, this is my best estimate of your problem. Hope this helps.
Jan 01, 2010 | Polaroid Televison & Video
Plasma TV - intermittent blinking
Power supply failure. Either a capacitor went bad, or there is a loose solder joint near the big transformer on the power board. I would guess loose solder connection.
Nov 14, 2008 | Televison & Video
Used TV; new to me
type in PT-47WX51 manual in your search bar and there is an online manual from fixya. It will take you through setting up your tv.
Nov 06, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Jun 04, 2008 | JVC AV-32260 32" TV
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
Panasonic older big screen tv
pls. check your cable box, if you have a cable box and it contain input- output audio video select video to your tv set maybe you scan from video 1-3. then check your RCA jack
Apr 10, 2008 | Televison & Video
Black box showing up while viewing DVDs
This sound like a problem with the Closed Caption, on many sets if the C.C. is set to text a black box apears, and since it only happens on DVD you might look at the DVD menu and see if it has this Text featcher in the Closed Caption menu and turn it off
Feb 13, 2008 | Televison & Video
Toshiba TV MV13P2
All I can say is that the black box appears when the closed captions are on and set to TEXT. This is normal. Turning off the closed captions should make the black box go away. If the closed captions are somehow turning themselves back on, there may be an issue with the microprocessor in your TV.
Aug 24, 2007 | Toshiba MV13P2 13 in. TV/VCR Combo
Computers & Internet Logo
14 people viewed this question
Alun Cox
David Payne
David Payne
